Xiaomi redmi note
juuzbe
Glass SP got difference between brands and sellers too. The better quality ones will have oleophobic coating which will not attract as much fingerprints and will be easier to clean and smoother to touch.
Can recommend?
Alexz_Hong
Can recommend?
I normally get mine from this seller on HWZ. Cheap,good quality (good oleophobic coating), and most importantly near where i live. Though i have not tried the redmi note's glass screen from this seller before. But i have gotten glass screen protectors for my iphone 5, 5C, and 5S, and all good quality. I wanted to get one for my redmi note a while back, but he was out of stocks then. :/
http://forums.hardwarezone.com.sg/m...or-9h-hardness-various-devices-4604949-6.html
juuzbe
using the mocolo one, seems pretty easy so far :s12:
Mine also Mocolo but from Qoo10 loh... feel that always have to keep wiping my screen very hard then can rid the 'oil' strips that stays on the screen everytime I swipe my phone. Wonder is it my screen or fingers problem. :s13:
hmm.. looks like the HWZ guy sell one similar price to my bought from Qoo10. Will try him soon. Thanks for recommend.
dealova
Can Goggle Maps points our exactly location regarding to GPS MTK issue ? (no rooted of course)
timpeh82
WTS : Tempered Glass Screen Protector 9H hardness for various devices - Page 6 - www.hardwarezone.com.sg
got mine from this guy too. very nice to see. i am using redmi note.
but...bottom corner of glass SP still not fully close up. very small issue.
quality can say 9/10.
halocast
mine also from qoo10, no problem with it..:o
eddy2099sg
Anyone receive firmware update but cannot download?
Yup same here. I am not sure if it was because of that unofficial patch I downloaded earlier to fix the camera bug which prevented it from saving to the SD card.
whoooo
If you root it need to run the updater and install the unroot in order to update
eddy2099sg
redsox
Mine is not rooted but also unable to upgrade- "An unknown error occurred while the update was downloading".
whoooo
Don't think I rooted the phone. Any case, it seems like I might not be the only one with the issue.
Did you managed to update your phone ?
Redmi NOTE-WCDMA Stable Version(Global) JHDMIBF28.0 Changelog & Download - Redmi Note - MIUI Official Community seems to show that the download file is missing, probably it got taken off or the link is wrong.
hmmmm I am on ver 25 and check there is no update...knowing Xiaomi they got a bad habit of releasing fw and taken it off the nextday from server.. happen to my son MI3 when they release the kitkat and remove from server the next day due to multiple complaints of lag on the new fw.
eddy2099sg
My redmi note update page as follows
I did get that notification about the update but couldn't download it. Same issue even after I removed the camera fix.
yan.an
Server is up, successfully updated to build 28.0, ANDROID appears on boot screen, cool!
Don't know why can't work on mine. After downloading, my phone reboot and the mitu appeared with an error code. I tried twice and both times I had to long press power button to reboot my phone.
