Xiaomi redmi note
halocast
Done :D
At the update screen, bring up the contextual menu (first capacitive button - 3 horizontal lines) and select the update from there. It will download a 558mb file and that did the trick
at this screen when i press the horizontal lines, only the clear ram thing come up :s11: how to select the update?
eddy2099sg
Just Me
I think there's no native root for the latest update like v25 right? Think I'll wait awhile..
whoooo
It's on the MIUI website and it was a little complicated getting the link.
Anyways, you can download from the link below and place it on your Note.
https://www.dropbox.com/s/5hytnuhod5649in/101118rcwewwgigmgdnk3i-1.zip
Then in the System Update screen, bring up the Contextual Menu and do a "Select Update Package" and select that zip file. I guess you know the drill. :D
Thanks bro
Lol I tot just restore the camera patch will do. Was afraid of restoring the whole 500mb plus file. After restore is it virgin or whatever is still left ? Damm lazy to reinstall the app n contact
eddy2099sg
Thanks bro
Everything is still intact. No need to reinstall any apps or anything else. It doesn't mess up the data.
Oh ya, this patch didn't fix the camera saving to sd card issue. I will see if I can do the patch again. Will update on that status.
whoooo
Ok. Anyway someone post a orignial patch file Redmi NOTE-WCDMA Stable Version(Global) JHDMIBF28.0 Changelog & Download - Page4 - Redmi Note - MIUI Official Community
I testing now to see if no need to do a full restore
Edited. The original cam file can flash but still error
eddy2099sg
Installed the camera patch on v28 but it didn't change anything. Photos still saved in the internal storage. Will replace the camera app for now.
yan.an
whoooo
eddy I tried your method twice and still get the same error code :(
Under updater choose View available update u will see a 533mb file
Wah lao..i Guinea pig for u....Cool the root for ver25 works on ver28
yan.an
Try again in a few days time. I actually don't see any noticeable differences between v25 and v28.
All right. No more testing for me for now. The picture of the mitu lying on the ground injured is quite depressing. LOL.
Just Me
Kam sia for testing out the native root :D
So I just need to use the native unroot first before updating this 533mb file?
poiiop
After updating the mail app changed its interface but becomes very sluggish..
Edit: I deleted my hotmail and re-added and it's fine now.
Anyone's calendar month view has got Smiley faces and sad faces on some of the days?? What are those?
galliano
Had no issues whatsoever with the update
It actually prompted me the update when WiFi was detected.
But...... Dammmm ... Its still JB.
tjkb230
Updated the new firmware
then flashed the camera patch to save photos to sd card
no issue:s12:
eddy2099sg
no issue:s12:
The camera patch works ?
For me the patch installed without issue but the photos are still saved in the internal memory.
