Xiaomi redmi note
MRC
Hopefully will? Lol. If I recall mediatek's source code for android are closed sourced, and they should be or should have already released the codes for 4.4 to manufacturers. :/
Alot of manufacturers have the source already its whether they wanna upgrade it anot. Even small china makers have updated their MTK phone to 4.4.2 already.
swgj86
well, don't get your hopes too high on having 4.4 delivered to the Redmi Note.
*If you know what I mean* There are things that I am not authorized to say or reveal. =X
swgj86
Hi Sidney, thanks for clarifying. Also nice to hear that battery life is great too. Now... Just have to get our hands on one... Lol.
I don't know if I should get one or just use the review unit.
The rate at which review units come in, buying a phone seems redundant. The Note seems too tempting even though I find it a tad slow. HA!
Good luck on Tuesday, everybody!
mingfreakrsx
well, if you want Android 4.4, maybe getting 1S would have more chances of getting it since its CPU is Snapdragon 400 by Qualcomm..
AphoticFX
hi guys,
does anyone know if it's possible to directly record videos onto the SD card and is there any recording time restriction?
galliano
Aww.. was kinda hoping that the Redmi Note would get Kit Kat.
poiiop
Hi guys, currently what the 99-100% sure ways to identify a fake Redmi Note?
1) SN is 01234567890ABCDEF
2) Check Imei and SN on XM site
3) Run Antutu
4) Run CPUz
5) Cannot update ROM to JHECNBE23.0 (V5)
Anymore?
ahtai_7
Hi,
can check if there is GLONASS?
this MTK chipset should not support Glonass but it's stated in the product specs.
GPS is the key reason i'm getting this so any clarification will be useful to all :)
Other than that, can Sidney share about GPS locking time in SG?
Thanks.
kopi22
hi guys,
Still not fixed yet AFAIK. Even saving photos to SD card via the default camera app is also impossible. You need to use Camera360 though.
MRC
If MIUI doesnt come with 4.4 then if you want it then try other China OS by China Modders. They will surely do it for XM Note. But whether the OS is good or not this you have to test it then you know. So far China modders had been doing alot of Custom OS already.
MRC
3) Run Antutu
4) Run CPUz
Anymore?
Another good way is to compare the quality and moulding marks on the cover itself but since you do not have another confirmed original note best is to compare pics online. Then also run 一键测机。It have spec and testing scores of the real note so it will tell you directly if its real or fake.
poiiop
May I know download from where? Can't find it in MI store nor playstore.
poiiop
Ok.. now i'm in a fixed. I bought a Redmi note yesterday at SLS (i already can hear people say 'wahlao why buy from there. 99% fake').
Based on the 5 steps I listed just now:
Mine is not
Do not exist in the website (according to box, unit manufactured June '14)
3) Run Antutu
Able to download from playstore and ran a score of 26000+
4) Run CPUz
Able to download from playstore. Nothing skeptical from the results
Prompted me to download over the air and I did it successfully in 1 try
Installed Ludashi app, had a score of 36688 and it says it is a '真机'.
So, did I buy a fake one....?
MRC
Mine is not
3) Run Antutu
4) Run CPUz
Strange why the imei and serial not in the system? Does your box have the security sticker to scratch it off to check it in their website? Try that.
Very fishy about it why the imei and serial issnt in their database. Perhap you can email them to check it out too.
Also check if box and phone imei is the same too.
poiiop
Box and phone IMEI are the same, I checked on the spot.
I didn't know about the scratching part. Have to go home and check.
When I was checking the first set they show me, I noticed Google Play Store already installed. Then I checked the SN, turns out to be 1234567890ABCDEF. I told them it's fake, but they say 'no, it is because it has been rooted'. But they offered to change a new and 'unrooted' one for me, which is the one I have now.
MRC
Your is the normal or enhanced Note?
Normal Antutu will be around 24000-25000, Enhanced is around 27000-28000.
MRC
This is the pic link for the hologram cum scratch off to check it online.
http://img07.mifile.cn/v1/MI_55950AFBBEDCB/T1YzWvBXbT1RXrhCrK.jpg?width=650&height=650
If you say that can show u the first set like that the shop is fishy already. Just curious how much you bought it for?
