[Monitor] Crossover IPS LCD 27 inches
singupingu
How high is the chance to get a unit with dead pixels problem? Saw quite a few complains in this forums regarding the dead pixel which I'm very conscious about it. Thinking to get a Qnix as followed.
Can draw an additional $20 cart coupon and $20 cashback from credit card. Wonder should I get this or be fuss free and get prism+ z270 from Aftershock.
Sent from Overpowered Phone Mark III using GAGT
IloveEmma
any thoughts about this monitor? Specs look very good! So tempted. Waiting for discount though.
http://list.qoo10.sg/item/CROSSOVER...100-ANTIGLARE-DP-HDMI-DVI-3440X1440/513230324
Brand : Crossover
Model : 34U100
Panel : PVA
Screen Size : 34" (21:9)
View Angle : 178°
Resolution : 3440 X 1440 100Hz (WQHD)
Response Time : 3ms (OD)
Brightness : 300cd/m²
Contrast Ratio : 3000 : 1
Dynamic Contrast Ratio : 5000,000 : 1
Color : 16.7M Color
Connection : Displayport, HDMI, DVI
Surface Treatment : Anti-Glare Type, 25%
Cross Hair Target : Yes
Flicker free : Yes
xtractor
Brand : Crossover
Model : 34U100
Panel : PVA
View Angle : 178°
Color : 16.7M Color
Flicker free : Yes
much better if u have AMD GPU because it support Freesync.....
singupingu
wah thanks! this looks exactly like the crossover monitor! It is VESA ready? and also I can't seems to find the amount of ports on this..
Not vesa mount compatible unfortunately. There are compromises too. And the monitor height is pretty low. You might need to have a platform to lift it up to your eye level preference.
If you can live with this compromise (I do), then the warranty provided is good for the price to be paid
Ya, the spec sheet not available for now. You can call Aftershock to inquire. They have sample display model to confirm your inquiry.
IloveEmma
Yes. Price looks very good. Very pity about the VESA which is a deal break. I plan to mount it as my desk is very short.
IloveEmma
alexion2k
Well, if anyone wanna get the Crossover FAST 27" 144hz, I have one brand new to let go. Just realised it's sold out currently at Goni. Bought two last month but realised two 27" is slightly too wide for me, might consider downsizing it to 24" 240hz monitor, so still reconsidering my options until my other pc parts reached sg by end of the month.
Still brand new in box, I have yet to open up the another one. Bought from Goni qoo10, perfect pixel + SG plug for $455 after the $110 voucher. Should be letting off at this price as well, just hit me with a pm if interested. If no taker, I will just open up and use it when I assemble all my parts end of the month.
Magickiller9
waaa if end of month no 1 want i'll consider...saving money now..
singupingu
Those looking for x340 or x315 from AFTERSHOCK Prism+ monitor, have good news for you directly from Prism+ :)
Aftershock is customizing a converter to use vesa mount for their ultrawide models. So, if you can wait, other than the attractive price + local warranty, this is something you can expect in near future. No news on the eta, but at least we know there is hope to snag an ultra wide monitor with vesa mount at a good price tag :)
i1magic
Ok. Glad that both monitor lasted till almost 4yrs. After the small hiccups on one of the monitor about 1.5yrs mark .... now the other monitor is having a slight issue.
Please see video for the fault.
Ok. The fault of this is the power adapter spoiling.
I managed to find the power adapter on eBay :
http://www.ebay.com.sg/itm/4-Pin-24...pply-/291755524270?hash=item43edfc00ae&_uhb=1
But sadly, it doesn't work when I received it. I found that that the problem was with the polarity of the 4 pin connector.
This is the polarity of the power adapter :
NOTE : Both left side are +ve
But the polarity of the power adapter I got, is this :
NOTE : Both top side are +ve
The polarity are wrong.
So out of desperation and with the help of a guy I know, I have to do some DIY work.
It worked!!
So just to test it out and get an power adapter as standby, I bought this power adapter (with output 24V 5A but NOT the 4 pin connector) :
https://www.aliexpress.com/item/1PC...32576130140.html?spm=2114.13010608.0.0.oVa1d1
For about SGD$17.20 (now price has gone up, so you may want to search for another)
Vs the one I got from EBay which is about SGD$40!
Got it and connected the 4 pin connector to this power adapter and it works flawlessly.
The power adapter of my other CrossOver monitor is starting to fail. Same symptoms as shown in the video above.
Since I already bought a power adapter for standby, I just use the method shown in the 2nd video to switch the connector over.
Now I have to buy another power adapter for standby liao.
i1magic
I agree with you. Basically, when we are paying more, we are paying for the additional specs + warranty.
I actually ordered 2 x CrossOver 27Q with stand on 21 May 2012. On around Jan 2014 (about 1yrs 7mths after), one of the monitor starts flickering and eventually the screen blacked-out.
After some research, open up the monitor and found out that the LED driver board has a chip that is toasted. Contacted the seller and asked for a replacement LED driver board. Cost me about SGD$60.
They sent it over to me. I opened up the monitor, replaced the LED driver board and *finger crossed* the monitor has been serving me well since.
Yes!! Celebrating 5th year on this 2 beauty!!
yiren1
Good Good morning guys,
I'm facing some difficulties trying to power up the monitor. I've attached video in regards about the issue I'm facing. Initially, the monitor will auto switch on and off for awhile. Sometimes i power off the monitor and on it back it works but not currently. Please help what's the issue is
I've purchased the monitor, crossover 27 fast 144hz on 23/01/17
Here's the link to the video
https://vimeo.com/216788633
Best Regards
Yire
bibu00
I bought a crossover 324ks today.
Hope i win the monitor lottery :D
http://list.qoo10.sg/item/CROSSOVER...OME-MONITOR-UHD-4K/513995142?selectedOptions=
Anyone knows whats the difference between the 324ks and the 324k? This model seems popular on overclock.net
Update on this. Don't buy from goni global on qoo10. Quite certain something is wrong. Till now I haven't Recieve my item. Its been 3 weeks! Takes them 3 days to reply a simple message.
going to get a refund. Don't buy from goni global!
yaqin123
sweet. looking forward to this, thanks for the info!
