[Monitor] Crossover IPS LCD 27 inches
i1magic
Hi I suspect I got spoilt power adapter as well. Do you mind sharing where to get a replacement for $40?
Is your monitor showing this symptoms?
If yes, can get this power adapter.
Item : 24V 5A 120W AC/DC power supply adapter
Price : About SGD$14.10
Source :
https://rover.ebay.com/rover/1/711-...979473?hash=item5686379e91:g:ZW4AAOSwiYFXK~A7
Then follow this video :
To change the connector.
It will work. Since it is only $14, I bought one and did exactly shown in the video and now I got a spare power adapter for standby.
godchuanz
Not exactly the same issue, but a similar issue diagnosed to be due to power adaptor fault - the screen will blank off after some time, needs to turn off power for a short while and turn on again.
Anyway, thanks for the links.
Do you know if there's a place to buy a 4-pin DIN instead of cannibalising the older adaptor? I saw some on aliexpress but they don't have the red/white wires, so a bit worried to follow your procedure. :D
i1magic
I didn't bother to find because by using the method I show above, the same connector can be used / switched to different adapter. Plus there is nothing that you can do with the spoilt power adapter.
Or do you have some plans for the spoilt power adapter?
Anyway, I did a quick search but I can't find any. So easiest will be just use back.
BarbieDog
interested in getting a 27 inch qhd monitor.
any recommendations and where can get cheaper ones?
look at qoo10 but all like no stock and got a lot model, don't know which one to look at.
keep looking at qnix and read at overclock forum that crossover is better now.
th3pr0
I'm using crossover fast 144. A QHD monitor with 144hz. So far so good however there is a little blacklight bleeding which seem to be normal even among big brands like Asus and ACER
BarbieDog
where did you get it? any promotions now?
BarbieDog
still no discount and stock sia. waiting for goniglobal. hope got a lot discount
babyalann
I'm personally using the 27Fast crossover 144hz from goni global. Best hoot 2016
Sent from OnePlus ONEPLUS A3010 using GAGT
Audiology93
I'm using one. CMI. Avoid it. 3 dead pixels. 2 spots that looks like dust. I even paid for the "perfect pixel. In the seller asked me if I want to keep it and issue me a refund on the extras paid for the" perfect pixel" or I can ship it back for another one at my own cost. LLST take the "$50" refund.
Sent from HUAWEI MHA-L29 using GAGT
BarbieDog
wah got so bad ?
i think really must see luck sia. what are you using know? do you have any recommendation?
I wanna go 27 inch QHD. don't know if i should go 144 hz also cause my budget not very high. $500 already very expensive for me.
babyalann
I Ordered a pixel perfect version from Goni Global and got about 5 Deadpixels at the corners so it doesnt affect me unless i put my nose on the screen. Goni states that their pixel perfect ver is 0-5 deadpixels so you cant really get 100% perfect.
th3pr0
you buy from goniglobal also? did you get the perfect pixel?
actually i got from another seller.. dream-zone i think. but they declare the amount as 600 even though i only pay 379 so i had to pay gst.. but still a good price so whatever
