if you have an Exynos vs Snapdragon with similar usage pattern, Snapdragon will have 10-20% more at the end of the day, irregardless if you're gaming or not.
Of course bro. Snapdragon no 5g so its totally useless in sg..
those with HK sets, have you guys got the OneUI 3.0 update?
Any idea when we getting it?
Note 10+ also a good phoneWhy N10+ over the normal Note 20?
Guys I am using note 20 for three days and I realized the battery is horrendous. Full charge before going to work. Went down to 50 px n charge up to 80% then ended the day at 10pm with 25% remaining. Is this normal?
Use money to buy a 120hz compatible phone but need to turn it off for battery, cmi la Exynos, what for waste money for this, some more can’t 120hz + wqhd
Now still so bad? Thought i read somewhere batt life for exynos increased after some software upgrade
Was looking at getting local set to play. Time to drop the idea![]()
i already made a post abt this on how u can get one ui 3.0 update on ur phone by changing the csc. look for my guide.Not yet. Dunno when also...
Sent from LGE LG-H930 using GAGT
Bro, your how's the Note 10+ battery life? Are you using SD or Exynos?Note 10+ also a good phone
I still using Note10+
Bros for you ah- should I get the note 20 or note 20 Ultra? Which is more worth the $?
Also the reason I'm getting the Note 20 is for writing. Is Easy Writing Pad (which can be moved around the screen) available in Note 10+?
exactly my point
this phone capable of 120 Hz super bright screen, but if you switch off the 120 hz and dim the screen all the time, might as well don't buy this phone
so my 3-4 screen on time is based on full capacity of phone, 120 Hz, quite bright screen, occasional gaming, web browsing most of the time, youtubeing also
yep hard reset. make sure u backup everything first so u can restore later..Change csc need to hard reset right? Think I wait. Waiting for s21 ultra see how also.
None. Just get the S21 coming up this month....why buy an old model?
