Samsung Galaxy Note 20 | Note 20 Ultra
sstimo
if you have an Exynos vs Snapdragon with similar usage pattern, Snapdragon will have 10-20% more at the end of the day, irregardless if you're gaming or not.
Of course bro. Snapdragon no 5g so its totally useless in sg..
ltrinityl
those with HK sets, have you guys got the OneUI 3.0 update?
Any idea when we getting it?
aw1007
Anyway, 5G is completely useless now.. in current infancy state...
Sent from Samsung SM-N9860 using GAGT
n1ef5ng
Guys I am using note 20 for three days and I realized the battery is horrendous. Full charge before going to work. Went down to 50 px n charge up to 80% then ended the day at 10pm with 25% remaining. Is this normal?
rabbit1
Yes. You're using an Exynos chipset, which is well known to have poor battery endurance.
cydutzyahoo
Use money to buy a 120hz compatible phone but need to turn it off for battery, cmi la Exynos, what for waste money for this, some more can’t 120hz + wqhd
exactly my point
this phone capable of 120 Hz super bright screen, but if you switch off the 120 hz and dim the screen all the time, might as well don't buy this phone
so my 3-4 screen on time is based on full capacity of phone, 120 Hz, quite bright screen, occasional gaming, web browsing most of the time, youtubeing also
cydutzyahoo
Now still so bad? Thought i read somewhere batt life for exynos increased after some software upgrade
:s13:
Was looking at getting local set to play. Time to drop the idea :s13:
Heard latest update (that we singapore haven't got yet) android 11 one UI 3.0 will greatly improved battery, until equivalent to Snapdragon, if reddit to be believed
who knows, let's wait and see for user feedback after update (based on note 9 experience, singapore samsung will dilly dally slowly release, not diligent enough. other country already update since last month)
singapore so small, dunno why so slow, samsung sg jin beh kan
DigDub
i already made a post abt this on how u can get one ui 3.0 update on ur phone by changing the csc. look for my guide.
Sent from LGE LG-H930 using GAGT
Change csc need to hard reset right? Think I wait. Waiting for s21 ultra see how also.
apostrophe
Note 10+ also a good phone
I still using Note10+
Bro, your how's the Note 10+ battery life? Are you using SD or Exynos?
Also the reason I'm getting the Note 20 is for writing. Is Easy Writing Pad (which can be moved around the screen) available in Note 10+?
lcheowl
If you use 60hz on N20U and with 5G off, the battery lasted slightly longer than n10+ (both local set), just that it runs a bit warmer than N10+ especially when you are using for a long period.
Zinc-Oxide
Why can't we buy and do what we want on our phone le? Some people prefer to set 60hz with Qhd and doesnt mean he or she cannot buy this phone le.
That's the reason why samsung put two options for us to use. You want battery life 60hz, you want shiok shiok 120hz then go for low battery,
exactly my point
Glariel
my note10+ is exynos local set
still drain quite fast
but also depending on the app you use
easy writing pad i got no idea, cause i dont use that
cydutzyahoo
anybody tried screen-shotting their singpass and unable to due to policy?
how to bypass this?
Wolfmaster
None. Just get the S21 coming up this month....why buy an old model?
Price have gone down quite substantially.. so to some might be a good times...
plus S21 price should be higher vs... Note 20.. so it makes fully financial sense for some..
