Did they replace the screen or replace the handset?
Replaced screen. The screen comes with new battery as well. Maybe glued together.
so they could not force you to factory reset? after repair all intact?
The battery isn’t glued to the screen according to tear down.Replaced screen. The screen comes with new battery as well. Maybe glued together.
Nope, its not glued together. But to replace the internals, the battery needs to be pried out so mostly will bend a bit, hence the replacement
Also need to replace gasket seal upon asembling back the bezel. But glue wont be as good as original, causing a decrease or lose of ipx rating.
update on screen on time
without power saving about 3-4 hour SOT
with power saving about 6 - 6.5 hours SOT
app usage is almost the same, play same game, watch some youtube, browse some site
this makes me wonder should switch on power saving most of the time for the almost double SOT
To all SD HK set users.. OneUI 3.0 update is out!
Bro how's the batt life on the SD so far? Thinking of getting the HK version too.
Note hk version don't have volte on starhub and no 5g.
Hi,
YouTube
Browser based video playing
DuoYin
Is what I use daily.
I think I'm probably getting around 7-8 hours of On screen time?
I havent got the chance to run down it to zero yet.
But usually at 60% I have about 3 hours of sot.
At 30% I would have about 5.5-6 hours or SOT.
It's not as good as my Huawei mate 20x for sure, but then that's 60hz. I'm running on 96hz. If it's 60hz I think 9-10 hours of sot is do-able.
Overall I'm quite happy with the battery life, at least I don't have to carry a brick around eg s21 ultra.
Makes me wonder Is there any point to getting a Snapdragon version now?
exynos version will feel hot and warm while using?
i'm still using huawei mate 10 pro, looking to replace it
hai if only new huawei phone still can use google service............
If you don’t mind no 5GStill worth to buy SD set now?
Sent from OnePlus KB2000 using GAGT
