RTX 4000 series thread... [No scalping discussion]
bakasora
I'm thinking to buy 4090. Last time got the power connector catching fire issue. Is that still an issue now? When you buy the adapter comes with it?
uselessbum
The power connector issue was actually user fault. They either never plug in the adapter fully or they bent(because squeeze inside small case) the adapter cable until it stressed the connector.
Yes, all 4090 comes with the 12vhpwr adapter though there might be a difference of 3 or 4 PCIe depending on the model you buy. If you worry about the adapter then alternative is to use native 12vhpwr cable by getting an atx 3.0 psu.
Matrix23x
native better and safer, so far so gd for mine, 1 cable only Corsair :wink:
wlalala
Hello
Is 4070ti good enough for 4K? or is it worth paying 500 dollar more to get 4080?
one of the more demanding game I play is microsoft flight simulator
No need 100fps, 60fps enough...
crystalnox
Hello
At 4k, your consideration should really be 4080 vs 4090. ;)
dexboi
my cpu have been revving so hard after the recent GeForce update.
until i realised the multiple instances of NVIDIA containers in Task Manager.
