dynacore selling TUF 4070TI below 1.2k
But must use new connector![]()
wow how to buy? go their physical shop or?dynacore selling TUF 4070TI below 1.2k
It on their Q10 storewow how to buy? go their physical shop or?
see you like adapter or native lorI thought 4xxx series come with 12vhpwr adapter? Don't tell me only the high end ones like 4080/4090 have?
I'm thinking to buy 4090. Last time got the power connector catching fire issue. Is that still an issue now? When you buy the adapter comes with it?
The power connector issue was actually user fault. They either never plug in the adapter fully or they bent(because squeeze inside small case) the adapter cable until it stressed the connector.
Yes, all 4090 comes with the 12vhpwr adapter though there might be a difference of 3 or 4 PCIe depending on the model you buy. If you worry about the adapter then alternative is to use native 12vhpwr cable by getting an atx 3.0 psu.
4k best is 4090Hello
Is 4070ti good enough for 4K? or is it worth paying 500 dollar more to get 4080?
one of the more demanding game I play is microsoft flight simulator
No need 100fps, 60fps enough...
At 4k, your consideration should really be 4080 vs 4090.Hello
https://www.tweaktown.com/news/9074...pu-usage-issues/index.html?utm_source=dlvr.itI rollback mine to previous version and will for the next official whql driver instead ...
