Safe to flash CN to Global?Flashed all 3 Ax9000 (2 CN , 1 Gobal) so far so good.
BUT flashing Gobal version of Ax9000 is not recommended. There is a 50% chance that it will bricked.
Why do you want to do that?Safe to flash CN to Global?
All my xiaomi products are in Singapore regional. Only the router are in CN. Very troublesome to keep toggling.Why do you want to do that?
Short answer is No.All my xiaomi products are in Singapore regional. Only the router are in CN. Very troublesome to keep toggling.
Is it worth to flash from CN to Global?
xiaomi ax10000 available now, with 2.5gbps and 10gbps ports. would be interesting to see how it fares against the ax9000
yes you can.Is it possible to get the router from China and use in Singapore?
Is vlan useful? How much do you save getting chinese version?yes you can.
I bought the chinese version of AX3600 to use locally.
Unless you need to use the VLAN functions, then you need the international version.
This is what I had gathered from reading the comments over at the AX3600 thread.
vlan so far i think its for singtel services...so i am no IT expert haha...Is vlan useful? How much do you save getting chinese version?
Wah! How big is your house? Need 1 x Mi Router AX9000 + 1 x Mi Router AX6000?Any owners of ax9000 still using it? Hope anyone can shed some solutions.
Recently installed Pihole to utilise my raspberry pi 4b lying around.
Discovered a device on my network keep pinging xxx.pool.ntp.org a lot. I.e 192.168.1.24
I wanna find out which bugger is doing that, but I realiSe I got problem finding it on router admin page. At DHCP section.
The closest way to it is IP reservation section where I can reserve IP for specific device thru it’s MAC address.
Even at this part I can’t find the device that using .24 yet pihole detected this IP has been top host doing requests.
I’ve resort even using Miwifi app scrolling thru the connected device list but with no avail.
anyone have any tips to view the IP table list? Will really appreciate any constructive answers! Happy new year!
EDIT: found it. its my mesh router ax6000, out of desperation, i access 192.168.1.24 it opens my mesh partner router log in page!![]()
just to ask, the lowest-end wifi6 router with usb port currently is this AX9000?![]()
Yes this seems to be the case for AX routers.
However, the USB port may or may not be that important if you use Xiaomi Stock FW. As per the review, USB SSD read/write performance is good, but then the overall router FW feature of Xiaomi AX9000 is rather limited which is kind of not matching the excellent hardware. So it depends on your use case.
Ref:
https://www.digitalcitizen.life/xiaomi-mi-router-ax9000-review/2/
currently using Mi Router 3 pro, I'm considering upgrading options for wifi6 and retaining the mini Nas function via usb port.
However this ax9000 abit too highend at near $300 for my usage (500mbps plan) sadly![]()
