Hypernova
- Feb 9, 2011
mine bloated like not long ago... actually im more concerned is it safe to continue using...
Better not. Imagine the phone explodes when you are using it. Not worth the risk ...mine bloated like not long ago... actually im more concerned is it safe to continue using...
Please send updates!wow didn't know of this. Let me give the service centre a try for X3 NFC battery replacement.
thanks!!
Read HWZ Forum Rules!
For my wife case, yes she does charge to 100 often. For my mi a1 is due to old age.charge to 100% often? plans to change the battery?
https://www.mi.com/sg/support/guidance/materialprice
I guess poco x3 nfc isn't too great ufs2.1 and all that, but should still be good enough as a handled down phone and cheaper than a new phone.For my wife case, yes she does charge to 100 often. For my mi a1 is due to old age.
Already bought new phone Liao, so not changing batt. 3 years is long enough la, due for a change
Assuming things go smoothly, anybody gotten their battery replaced before?
ie: battery isn't too old stock, stored properly so it isn't already deteriorated (capacity 95%+ hopefully maybe?) and if they try to add extra charges due to bs reason such as the cover being non-removable so they have to replace it instead of just the glue
Mine is bloated too.
it depends lor, my wife's set experienced charging issue before visibly bloatedMine is bloated too.
Not sure if it is defects that affect all Poco X3 NFC.
Poco X3 NFC Telegram Group people around the world is experiencing this problem.
Although the battery is bloated, the battery life is still surprisingly good.
Sending the phone to Official Xiaomi Service Center will need to do a full wipe before they inspect the phone.
Not sure if worth the pain of backing up the whole phone just to send for inspection.
Out of warranty Servicing fees is not that cheap too.
Every battery get bloated eventually.Mine is bloated too.
Not cheap but if get at least 6 more months, is worth it maybe? battery replacement is for under $50.Out of warranty Servicing fees is not that cheap too.
I think it depend on how much care, like during fast charging, not using it, have some cooling like fan blowing on it, charge to no more than 80%, which is what I do.it depends lor, my wife's set experienced charging issue before visibly bloated
when did u get the X3 and how's the usage like?My X3 NFC finally going through hospice care. Battery bloated and it doesn't charge anymore.
my battery down to 35% and I have it on ultimate battery saving mode. hopefully it can last until my new F4 arrives.(shopee say will deliver by 19th
somewhere early 2021.when did u get the X3 and how's the usage like?
have to admit, i usually charge it overnight when i sleep, probably overcharging by a lot. light gaming on it, doesn't get the phone too hot, probably at most lukewarm to the touch if i tend to play too long on it like continuous over 2 hours or so
this is actually the first phone i had with fast charging tech, my last phone before X3 NFC was LG v30, charge overnight batt doesn't bloat. but usually after 3 years+/- battery life is short, 100% to 20% after about 16 hours normal daytime usage.got mine in end 2020..think mine gonna bloat soon as well..I don't charge overnight though. usually charge for an hour.
I over night charge using iPhone charger (the small one)My x3 pro was 11-11 2021. Didn't realise it's turning 2yo soon. Due to my previous bad charging habits with Redmi Note 2, 4 and Poco F1. I learnt my lesson to let my x3 pro run low until 30% or lower, then charge and try to unplug before it goes 100%.
X3 Pro with fast charging usually one hour is good enough to bump up 30-40%. That's why I almost never leave it overnight.I over night charge using iPhone charger (the small one)
you must be doing something wrong, it takes 15 to 20 minutes for 30% to 40% more on exisiting amount, for it to take 3 to 4 times longer, it's probably overheating and that's bad for the battery.X3 Pro with fast charging usually one hour is good enough to bump up 30-40%. That's why I almost never leave it overnight.
