It seems to me UDM Pro and UDM SE are still an viable option for 10Gbps plan, based on the following video. It can do up to 9.3Gbps routing with NAT. I guess the reviewer's 10G plan is also good (maybe similar to the old VQ 10Gbps plan which uses Metro Ethernet).
keat84
Why don’t you get WiFi 7 APs or routers. Saw challenger already selling the TP link WiFi 7 router. To utilize the speed of WiFi 7, might have to upgrade network switches to 10G ports.
Yes, that what i planned but wan to check if single AXE-300 able to cover the whole house?
Do you mean TP-Link Omada series?
robolee
These using MR 10gbps can help me on this?
Hey Guys, can you help me ping 158.115.197.218 and tell me your ms.
Necromancer
--- 158.115.197.218 ping statistics ---
28 packets transmitted, 14 packets received, 50.0% packet loss
round-trip min/avg/max/stddev = 144.725/146.418/154.246/2.440 ms
robolee
yikes, definitely not recontract to MR anymore
limcc
Code:
Pinging 158.115.197.218 with 32 bytes of data:
Reply from 158.115.197.218: bytes=32 time=96ms TTL=47
Ping statistics for 158.115.197.218:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 96ms, Maximum = 96ms, Average = 96ms
MR 10Gbps thru GT-AX6000 on PC.
Thru Android phone with "Fing".
p.s. sorry for the big file, no time to edit.
robolee
Code:
why both MR user but ping so different?
Some MR users are still affected by the problem and some are not.
https://forums.hardwarezone.com.sg/threads/myrepublic-fibre-part-5.4981088/page-343#post-149956334
30/10/2023/ 11:48 am : Still after rollback we have identified 10G network broadband connectivity issue affecting some customers around central and eastern Singapore. Our vendor is currently investigating and we will share an update on the situation when we have more information.
TanRich
Welcome to the club. I remember the first week after service activated ethernet speeds were all over the place, VOIP apps (GoogleMeets, Zoom MS Teams) couldn't be used without major lagging. Then everything seemed to have stabilised after that. Today, MS Teams video call again lagged so bad had to switch to backup ISP to continue the call.
leongws
Reply from 158.115.197.218: bytes=32 time=399ms TTL=48
Reply from 158.115.197.218: bytes=32 time=141ms TTL=48
Reply from 158.115.197.218: bytes=32 time=140ms TTL=48
Minimum = 140ms, Maximum = 399ms, Average = 205ms
berlo84
PING 158.115.197.218 (158.115.197.218): 56 data bytes
64 bytes from 158.115.197.218: icmp_seq=0 ttl=48 time=141.770 ms
64 bytes from 158.115.197.218: icmp_seq=1 ttl=48 time=141.941 ms
64 bytes from 158.115.197.218: icmp_seq=2 ttl=48 time=141.885 ms
64 bytes from 158.115.197.218: icmp_seq=3 ttl=48 time=141.758 ms
64 bytes from 158.115.197.218: icmp_seq=4 ttl=48 time=141.690 ms
64 bytes from 158.115.197.218: icmp_seq=5 ttl=48 time=141.767 ms
64 bytes from 158.115.197.218: icmp_seq=6 ttl=48 time=141.947 ms
64 bytes from 158.115.197.218: icmp_seq=7 ttl=48 time=141.792 ms
64 bytes from 158.115.197.218: icmp_seq=8 ttl=48 time=141.890 ms
64 bytes from 158.115.197.218: icmp_seq=9 ttl=48 time=141.816 ms
64 bytes from 158.115.197.218: icmp_seq=10 ttl=48 time=141.781 ms
IHasChimken
Reply from 158.115.197.218: bytes=32 time=136ms TTL=48
Reply from 158.115.197.218: bytes=32 time=137ms TTL=48
Minimum = 136ms, Maximum = 137ms, Average = 136ms
robolee
From what i see, majority of you are 140ms and 1 is 100ms. And all of you are MR too...
SojIrOu
Ok that explains why then. My region affected.
Seems like Starhub was also affected but they kept quiet about it and refused to acknowledge any issue on their part when I called up to complain.
I'm also in the central/east area and I've been getting latency of up to 1000-3000ms and random disconnects on Starhub 10gbps plan starting Friday last week.
Speeds seem better today but still getting socket error when doing speedtest and up to 300ms ping.
Necromancer
For those facing the packet loss issues like I have on MR, I think its probably related to their internal routing.
I VPNed into one of my machine on a different network which interestingly enough it didn't get the packet loss. Since then I've been directing all my traffic through there until MR can resolve this.
