zym.sg Mobile (Singtel MVNO)
Bluey_06
no such thing happen to me
how you all even get all these funny tech issue
can use data but no sms
Yes weird. I even use another sim under prepaid on my 23 Ultra and it was working fine. The zym sim on another phone also can't rec incoming SMS but data ok.
ZYM kept telling me they checked I was able to use data and I kept telling them I can but I just cant rec incoming calls n sms
gapboy
sounds like your problematic phone issue
Jurong640
I faced the same issues for my S21+ when i port into ZYM. After i switch the ZYM SIM to SIM Slot 2, it works.
For unknown reason, SIM 1 can only have 4G data and cannot receive incoming and make outgoing calls. When check with ZYM, they say network is fine. Then i make the switch to SIM Slot 2, and viola it works.
Try it on your s23 ultra, sim slot 2
Bluey_06
Thank you. I din troubleshoot on slot 2 though. Will try this.
wira
for the $100 voucher can still use to get airpods pro ? saw they removed airpods from the site now
iamnagel
Received SMS that line was ported over last night. However, when I try calling the number it says Singtel number not in use.
Anyone encounter the same problem?
gapboy
S23 ultra red.
crystalnox
At least they raised it ~1% in line with the GST hike, unlike some other ONE telco who probably runs a coffeeshop drink stall as a side business too.
whatheheck
their HP store on shopeee so long liao, still don't want to allow payment through there :frown:
