- Jul 29, 2003
when someone wants to black something, they will think of anything. just ignore the troll.
Yes weird. I even use another sim under prepaid on my 23 Ultra and it was working fine. The zym sim on another phone also can't rec incoming SMS but data ok.no such thing happen to me
how you all even get all these funny tech issue
can use data but no sms
sounds like your problematic phone issueYes weird. I even use another sim under prepaid on my 23 Ultra and it was working fine. The zym sim on another phone also can't rec incoming SMS but data ok.
ZYM kept telling me they checked I was able to use data and I kept telling them I can but I just cant rec incoming calls n sms
I faced the same issues for my S21+ when i port into ZYM. After i switch the ZYM SIM to SIM Slot 2, it works.Yes weird. I even use another sim under prepaid on my 23 Ultra and it was working fine. The zym sim on another phone also can't rec incoming SMS but data ok.
With another sim on the phone, it is working fine. I use the zym sim on another spare phone, it can't work too.sounds like your problematic phone issue
Thank you. I din troubleshoot on slot 2 though. Will try this.I faced the same issues for my S21+ when i port into ZYM. After i switch the ZYM SIM to SIM Slot 2, it works.
For unknown reason, SIM 1 can only have 4G data and cannot receive incoming and make outgoing calls. When check with ZYM, they say network is fine. Then i make the switch to SIM Slot 2, and viola it works.
Try it on your s23 ultra, sim slot 2
Haha... Simba still $10 though.
you havent check redone plan > 1% incrementHaha... Simba still $10 though.
reboot your phone..Received SMS that line was ported over last night. However, when I try calling the number it says Singtel number not in use.
Anyone encounter the same problem?
