Groudon
- May 4, 2013
Well, in the States, AT&T provides XGSPON in many locations as well (albeit up to 5Gbit/s at the moment).It’s not about whether the speed is fast or not. It’s about false marketing… they cannot advertised 10Gbps but provide equipment that doesn’t provide the full bandwidth…
If it’s in the states, they would have been sued.
The technology does technically support a maximum line rate down/up of 9.953Gbit/s, and after the framing overhead, and accounting for usage across other users on the same PON port, you won't really be seeing speeds anywhere close to 9 Gbit/s.
This is wildly different compared to GPON, because remember GPON supports 2.4G down, but I guarantee you in residential usage, PON port usage is really low and can therefore accommodate the bursts from different users every once in a while. The same isn't true once you move up to XGSPON as all bandwidth available on the PON port is shared across minimally (I presume) at least a 1:64 split ratio on most providers.
