abstrax
- Nov 29, 2001
I did a research for be805 too. There is only 2x 10G ports.(1 WAN & 1 LAN)TP-Link Archer BE805 (BE19000) is better (about S$400 BNIB from Carousell).
Last time TP-Link Archer AXE300 (AXE16000) was also dumped in Carousell at around S$380 to S$450 BNIB when it was the bundled router for SH/MR 10Gbps plan.
Reference:
https://forums.hardwarezone.com.sg/...tarhub-myrepublic-simba-and-vq.6930337/page-3
I choose AXE300 in the end bcoz it has 2x 10G ports,1x 2.5G port, 1x SFP(might come in handy in the future) which serve my purpose as I no nid to get additional 10G switch to connect my 3 other pc.
Will be using 2.5G switch to connect them. (cheaper solution too as for now).
Actually at 1st I thinking to setup the network all using 2.5G router. But since AXE16000 comes with 10G port and it is compatible with my x540-t2, tats y i give it a go.
I dun nid strong wifi as i only use it to connect my ipcam. (only turn on 2.4GHz). I mostly connect my hp to my AP inside my room.
I do hope maybe in the next coming month, there will be more release for 10G home routers for us to choose from with all 10G ports with more affordable price.
