SIMBA Fibre Broadband
tewem
Currently on M1. I need NAT and not CGNAT for my broadband.
Should i go with Whizcomms 10Gbps or Simba 10Gbps?
Simba uses ONT device, whilst Whizcomms uses ONR device.
I prefer ONT as one can utilise one router's full functions. If you are on ONR device, you have to set your wireless router to "Access Point" mode.
If you have no preference, both can also do it.
Skypower
Simba ONT is not the same as StarHub ONT as Simba using CGNAT and Starhub assign Public IP.
if testing environment all remain same:
- On Simba, network performance can be affected by ISP CGNAT processing.
- On Starhub, network performance is affected by your purchased router performance, these with more powerful processor process NAT faster.
tewem
Hmm, I googled and got this:
Skypower
From your diagram "How CGNAT Works", you see two Private Networks (label as 1 and 2) in red color, which means two NAT.
From you diagram "How NAT Works", you see one "Private Network", which means one NAT.
- add info: the "Router + NAT" simply refer to your purchased WIFI Router such as eg.Asus RT-BE6500
mimi89
Hi guys, good day.
New user here, just subscribed to Simba home broadband, I paid for the ONT installation service.
Wondering, during the NLT activation time & date, does someone need to be physically there? They need to access to the premise?
After the NLT is activated, ONT will be activated on next working day?
Thanks a lot in advanced!
tewem
Hi guys, good day.
Regarding your Fibre terminal point, has it previously been used by another ISP and now it is free?
If it is so, no need to be physically at home.
After NLT is activated, normally another few hours will be able to be used.
mimi89
Hi bro, thanks for your reply, yes, it was previously used by the previous owner.
I received an email from Simba stated that NLT will just remotely activate it on 22th Jan.
It also stated the installer will contact me on next working day to schedule a "convenient" time for the installation of ONT equipment, so the installation will be fall on 23th Jan for my case ah ?
THanks!
tewem
THanks!
Yes, if you have chosen the date: 23th Jan, then the installer will come on that day to install.
I opted to self-DIY saving $39.00.
Singaporeans First
But SIMBA uses CGNAT and Whizcomms Uses NAT right?
I need NAT. Meaning i can only goes with Whizcomm between them?
Tundra
Hey guys,
Need some advice here. I recently switched from MyRepublic to SIMBA broadband and can’t get the internet to work. Here’s what’s going on:
1. MyRepublic service ended on 15 Jan, and the NLT activation for SIMBA was also on the same day.
2. After activation, I installed SIMBA’s new ONT but kept using my old routers (Asus and TP-Link) from MyRepublic. No internet connection.
3. Thought it was a router issue, so I tried connecting directly to the ONT, but still no internet.
4. SIMBA’s network team checked and said:
• The ONT is online and working fine.
• Optical readings are good.
• They noticed the device connected to the ONT might only support up to 1 Gbps.
5. Even with a direct connection to the ONT, I still can’t get online.
I’ve already reached out to SIMBA support, but they’re not super helpful. Anyone knows what could be wrong or if I’m missing something here?
Thanks in advance!
thiamhui
Hey guys,
Thanks in advance!
Did you subscribe "Static IP" previously?
Have you try hard reset the old routers and setup as new?
Apex
Hey guys,
Thanks in advance!
I think the usual troubleshooting steps are:
  1. Is the ONT working properly? Are all the lights OK, with no red flashing lights?
  2. Have you tried connecting your device (PC/Laptop via wire) directly to the ONT to check if you can get internet access?
  3. Regarding your old Asus router, what do you see on the primary router? What WAN IP are you getting? By the way, if you've configured it in AP mode, you will need to switch it to router mode or, as suggested, perform a reset.
Tundra
I did not subscribed to the static IP from MyRepublic.
Yes, I did a hard reset and tried on 2 old routers that I had (total 3) but still not able to the internet. The internet access light on my routers are red
1) I would think so. The lights on the ONT are green (Power, PON and 10G LAN). No light on LOS.
2) Yes I tried this method. I connected the ethernet cable directly from the ONT to my computer but still no internet access.
3) I have issue of my router unable to obtain an IP address from the DHCP server. It has been set as router instead of AP mode.
Thank you for helping me out on this!
Apex
Last question your Simba ONT connected to the right fiber port? I saw a few users plug in to Port 1 when their Simba is on Port 2.
I'm not sure how NLT setup your MR to Simba? Not sure if they on the same Fiber port or different.
luei74
Agree with post #3161. Try to test it on another port and report back.
Tundra
I have tried both ports but still has the same issue. how do I know which port is for my SIMBA broadband?
tewem
Diagnostic purpose:
Have u checked the fibre optic cable both ends, there is a plastic cap on both ends that needs to be removed.
Have u checked whether u have removed that?
Take note to be careful, do it slowly as not to damage the contact points.
Tundra
Diagnostic purpose:
Yes, I did removed the plastic cap on both ends before plugging in. SIMBA support informed that their Network Team has confirmed that the ONT is online, with all parameters functioning normally and the optical reading well within range.
I just bought the eero max 7 router and it still doesn’t work. I guess I will request for them to troubleshoot and setup my router at my home
