- Mar 22, 2011
Can't wait for 14 Feb friday for you to blew the competition with 5gbps on your phone.Records are meant to be broken. I will break him !!!!!!!
Bro wa stress leh, I try bah, but nothing crazy, don't want do excessive wear on the wifi chip lol ...Can't wait for 14 Feb friday for you to blew the competition with 5gbps on your phone.
More about HB410 and HB710 from Starhub Broadband Router FAQ. I think HB410 at S$120 can be a good mesh node for EB810v users if you want to save a bit of money and if you can use wireless backhaul.
https://www.starhub.com/personal/support/article.html?id=LfNB5odcBt0mTG6Pr7GSB7
Is the TP-Link HB410 a 2.5Gbps router?
Yes, the TP-Link HB410 is a 2.5Gbps router. It has a 2.5Gbps WAN/LAN, 2.5Gbps LAN and 2 x 1Gbps LAN ports.
How does the TP-Link HB410 mesh work?
The TP-Link HB410 uses Easymesh* technology and is compatible with another TP-Link HB410. For the best performance and compatibility, we recommend meshing with another HB410, HB710 or EB810v.
* Mesh nodes that are available from other brands would not be compatible with the TP-Link HB410. We strongly recommend using another TP-Link HB410, TP-Link HB710 or EB810v for the best performance.
I need more coverage on my home network with the TP-Link HB410, what can I do?
You can extend the coverage by purchasing another TP-Link HB410 from StarHub. Additional units can be purchased at $5 per month for HB410 during initial sign-up or cash & carry from our retail store and Hub Troopers at $120 respectively.
Is the TP-Link HB710 a 10Gbps router?
Yes, the TP-Link HB710 is a 10Gbps router. It has a 10Gbps WAN/LAN and 1 x 10Gbps LAN port.
How does the TP-Link HB710 mesh work?
The TP-Link HB710 uses Easymesh* technology and is compatible with another TP-Link HB710. For the best performance and compatibility, we recommend meshing with another HB710 or EB810v.
* Mesh nodes that are available from other brands would not be compatible with the TP-Link HB710. We strongly recommend using another TP-Link HB710 or EB810v for best performance.
I need more coverage on my home network with the TP-Link HB710, what can I do?
You can extend the coverage by purchasing another TP-Link HB710 or EB810v from StarHub. Additional units can be purchased at $8 per month for HB710, $15 per month for EB810v (for 24 months) during initial sign-up or cash & carry from our retail store and Hub Troopers at $192 or $360 respectively.
PS C:\work\speedtest\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.23 ms (jitter: 0.66ms, low: 3.08ms, high: 5.59ms)
Download: 54.07 Mbps (data used: 77.6 MB)
229.51 ms (jitter: 100.67ms, low: 2.81ms, high: 1462.52ms)
Upload: 301.55 Mbps (data used: 569.3 MB)
170.06 ms (jitter: 85.49ms, low: 5.41ms, high: 1080.39ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/e6f37633-0be3-43c0-85d6-c07fc40b74bc
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 6.54 ms (jitter: 5.35ms, low: 4.33ms, high: 15.12ms)
Download: 2523.95 Mbps (data used: 3.1 GB)
16.17 ms (jitter: 7.59ms, low: 4.55ms, high: 74.63ms)
Upload: 1515.31 Mbps (data used: 2.1 GB)
20.00 ms (jitter: 12.70ms, low: 5.70ms, high: 294.04ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/2048eb9e-87a8-42a0-8c9d-e7160404bd93
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.90 ms (jitter: 0.35ms, low: 3.70ms, high: 4.61ms)
Download: 297.47 Mbps (data used: 515.1 MB)
43.23 ms (jitter: 25.40ms, low: 5.29ms, high: 147.94ms)
Upload: 238.04 Mbps (data used: 409.6 MB)
217.10 ms (jitter: 69.57ms, low: 9.20ms, high: 669.17ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/bcbbc8fb-faa5-41be-9d9e-b72d5b150875
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.41 ms (jitter: 2.95ms, low: 3.27ms, high: 9.33ms)
Download: 152.46 Mbps (data used: 74.6 MB)
31.63 ms (jitter: 20.98ms, low: 4.92ms, high: 86.85ms)
Upload: 100.56 Mbps (data used: 143.7 MB)
54.88 ms (jitter: 12.62ms, low: 24.79ms, high: 185.92ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/7c5ead6e-9df8-4d98-8845-dc7b566c7f20
[2025-02-14 19:38:20.440] [error] Limit reached:
Speedtest CLI. Too many requests received. To maintain a fair and stable environment, please review and adjust the frequency of your requests.
PS C:\work\speedtest\iperf-3.18-win64> .\iperf3.exe -c speedtest.singnet.com.sg -p 5201 -R -P10
Connecting to host speedtest.singnet.com.sg, port 5201
Reverse mode, remote host speedtest.singnet.com.sg is sending
[SUM] 0.00-10.01 sec 3.22 GBytes 2.77 Gbits/sec 712 sender
[SUM] 0.00-10.01 sec 3.22 GBytes 2.76 Gbits/sec receiver
iperf Done.
[SUM] 0.00-10.01 sec 1.67 GBytes 1.43 Gbits/sec 53 sender
[SUM] 0.00-10.01 sec 1.66 GBytes 1.43 Gbits/sec receiver
iperf Done.
[SUM] 0.00-10.00 sec 1.97 GBytes 1.69 Gbits/sec 207 sender
[SUM] 0.00-10.00 sec 1.97 GBytes 1.69 Gbits/sec receiver
iperf Done.
[SUM] 0.00-10.01 sec 218 MBytes 183 Mbits/sec 294 sender
[SUM] 0.00-10.01 sec 211 MBytes 177 Mbits/sec receiver
iperf Done.
[SUM] 0.00-10.01 sec 3.09 GBytes 2.65 Gbits/sec 1164 sender
[SUM] 0.00-10.01 sec 3.08 GBytes 2.64 Gbits/sec receiver
iperf Done.
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.08 ms (jitter: 0.24ms, low: 3.89ms, high: 4.44ms)
Download: 2970.89 Mbps (data used: 5.2 GB)
14.85 ms (jitter: 7.21ms, low: 5.41ms, high: 48.19ms)
Upload: 1639.31 Mbps (data used: 2.9 GB)
13.81 ms (jitter: 6.49ms, low: 3.25ms, high: 56.65ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/8fe50d98-c0a1-4435-a550-b3c79464b600
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.97 ms (jitter: 0.55ms, low: 3.97ms, high: 5.44ms)
Download: 136.90 Mbps (data used: 168.4 MB)
228.06 ms (jitter: 99.56ms, low: 2.80ms, high: 780.97ms)
Upload: 357.25 Mbps (data used: 633.9 MB)
177.28 ms (jitter: 89.70ms, low: 3.21ms, high: 1350.34ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/b611c371-b2e8-41a6-ad91-8a61fef6e5fc
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.46 ms (jitter: 0.35ms, low: 3.12ms, high: 3.90ms)
Download: 87.70 Mbps (data used: 129.5 MB)
134.37 ms (jitter: 85.21ms, low: 2.73ms, high: 697.74ms)
Upload: 1035.93 Mbps (data used: 1.7 GB)
45.08 ms (jitter: 44.38ms, low: 2.73ms, high: 298.58ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/316ddbf0-4cf9-4a0a-9201-7ec64c031c50
Speedtest by Ookla
ISP: Singtel Fibre
Packet Loss: 0.0%
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.65 ms (jitter: 0.36ms, low: 3.37ms, high: 4.16ms)
Download: 1789.31 Mbps (data used: 3.0 GB)
15.56 ms (jitter: 8.07ms, low: 5.67ms, high: 109.33ms)
Upload: 1709.49 Mbps (data used: 2.4 GB)
18.93 ms (jitter: 14.87ms, low: 3.28ms, high: 252.70ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/d8acb2a5-3ddd-4ddb-b74e-1aa54bb116a9
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 6.57 ms (jitter: 6.85ms, low: 4.26ms, high: 19.35ms)
Download: 141.60 Mbps (data used: 139.8 MB)
46.42 ms (jitter: 25.79ms, low: 3.92ms, high: 287.12ms)
Upload: 107.55 Mbps (data used: 134.3 MB)
143.61 ms (jitter: 45.32ms, low: 4.12ms, high: 342.25ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/646490d2-f106-4a11-8709-93c733301e24
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 8.15 ms (jitter: 2.78ms, low: 6.31ms, high: 13.85ms)
Download: 2529.45 Mbps (data used: 3.5 GB)
21.08 ms (jitter: 7.52ms, low: 4.67ms, high: 62.42ms)
Upload: 2052.01 Mbps (data used: 1.5 GB)
14.30 ms (jitter: 5.33ms, low: 6.31ms, high: 67.91ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/36ca64ab-69fe-4aff-8bd2-7241066ea02a
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 6.15 ms (jitter: 0.71ms, low: 5.69ms, high: 6.62ms)
Download: 2658.20 Mbps (data used: 4.8 GB)
22.03 ms (jitter: 7.49ms, low: 4.59ms, high: 47.17ms)
Upload: 2098.76 Mbps (data used: 3.0 GB)
14.79 ms (jitter: 6.01ms, low: 6.36ms, high: 34.39ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/26b53fe6-a1bc-4edf-9cec-9c0add56791b
Redo the test for MLO SSID at 3m distance --> looks like Archer BE805 + Intel BE200 combination is not good for MLO as of now.
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 5.46 ms (jitter: 1.51ms, low: 4.02ms, high: 8.32ms)
Download: 27.00 Mbps (data used: 43.2 MB)
305.89 ms (jitter: 103.83ms, low: 4.70ms, high: 1216.44ms)
Upload: 252.28 Mbps (data used: 435.4 MB)
235.68 ms (jitter: 95.82ms, low: 5.08ms, high: 882.09ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/79a10db6-58b5-4c89-9c08-e880cd9da372
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.32 ms (jitter: 0.26ms, low: 3.83ms, high: 4.52ms)
Download: 26.64 Mbps (data used: 39.9 MB)
310.29 ms (jitter: 100.91ms, low: 3.83ms, high: 884.91ms)
Upload: 161.30 Mbps (data used: 255.5 MB)
227.52 ms (jitter: 97.54ms, low: 4.32ms, high: 917.00ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/c12e6237-6379-433b-813c-4da9931e1c87
It is the same today with very slow MLO speed. Looks like MLO is broken now with Archer BE800 + Intel BE200.
I guess I will have to wait for next Intel Driver update to see if the issue is resolved or not. TP-Link usually does not update router FW so frequently.
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.28 ms (jitter: 0.25ms, low: 4.01ms, high: 4.47ms)
Download: 1815.09 Mbps (data used: 3.2 GB)
16.34 ms (jitter: 6.44ms, low: 5.06ms, high: 60.49ms)
Upload: 1241.43 Mbps (data used: 1.4 GB)
26.56 ms (jitter: 12.16ms, low: 5.65ms, high: 111.19ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/d9203d99-0c6b-47ab-83eb-90d63e611ae7
FW functions of the TP-Link HB710 seems to be fine for most of the users. It lacks some features of the EB810v though.
1) DDNS --> TP-Link DDNS (need to log in with TP-Link ID), NO-IP and DynDNS are supported.
2) Wireless --> Guest Network is supported; MLO is supported (not able to select which bands to support, unlike Archer BE805)
3) USB --> USB storage sharing, 3G/4G USB modem (but it is a USB 2.0 port)
4) NAT forwarding --> Port forwarding (virtual server), Port triggering, uPNP and DMZ are supported
5) Security --> basic firewall and IP/Mac filtering, basic parental control
6) VPN client/server --> OpenVPN and L2CP/IPSec supported, no Wireguard support
7) IPv6 --> native IPv6 using DHCPv6/SLAAC, no 6rd support (Singtel 6rd IPv6)
8) System --> automatic FW updates, schedule reboot, LED control, traffic statistics, etc
This should be the cheapest 2x 10G port router available right now?
Any limitation with a service provider model? It's not lock to a specific ISP right?
For wireless mesh, do HB710 able to pair with any DECO series (e.g. BE85) or only with specific service provider model?
Is HB810 better than HB710 and be used with M1? HB810 seems to be identical with BE85? Can BE85 firmware be flashed on it?Yes, it is probably the cheapest as of now.
HB710 is kind of tied to Starhub/MR but in reality will work with other ISPs as well. As per the reports, users seem to be able to get FW updates when using other ISPs (but I cannot confirm this myself).
TP-Link HB710, EB810v and HB410 (along with SingTel issued HB810 and HB611-SGST) support TP-Link EasyMesh and they can mesh with other TP-Link Archer series routers using TP-Link EasyMesh technology, not Deco Mesh. TP-Link EasyMesh is not compatible with Deco Mesh.
Floor plan for reference: 1998 4-room HDB flat, 106 sqm
Router --> RT-AX86U
Router 2 --> HB710 in the above coverage test. Point A is the difficult spot with weak signal since there are two walls between the router and the test device.
Test device: Acer Swift Go 14 2024 model (Intel Core Ultra 5 125H CPU, 16GB, 1TB, Killer BE1750 WiFi 7 adpater based on Intel BE200 chipset).
Test results using TP-Link Archer BE805 (RT-AX86U is still there) vs RT-AX86U (HB710 is now OFF).
Looks like Archer BE805 5GHz band coverage is similar to RT-AX86U, better than HB710.
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 5.95 ms (jitter: 14.32ms, low: 4.94ms, high: 60.14ms)
Download: 311.03 Mbps (data used: 450.1 MB)
31.68 ms (jitter: 25.36ms, low: 2.43ms, high: 512.33ms)
Upload: 125.14 Mbps (data used: 216.0 MB)
340.43 ms (jitter: 71.91ms, low: 3.81ms, high: 794.45ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/63424596-cda6-4c54-9929-f5600d936537
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.55 ms (jitter: 0.21ms, low: 3.36ms, high: 4.03ms)
Download: 338.42 Mbps (data used: 575.9 MB)
23.03 ms (jitter: 12.62ms, low: 3.43ms, high: 86.00ms)
Upload: 142.87 Mbps (data used: 238.1 MB)
265.59 ms (jitter: 73.55ms, low: 10.71ms, high: 510.10ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/efd13c51-0a68-44f0-bbae-35702251530e
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.72 ms (jitter: 2.98ms, low: 2.50ms, high: 10.97ms)
Download: 94.09 Mbps (data used: 89.3 MB)
95.16 ms (jitter: 50.34ms, low: 4.96ms, high: 422.43ms)
Upload: 35.55 Mbps (data used: 31.1 MB)
605.74 ms (jitter: 86.24ms, low: 7.57ms, high: 1293.35ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/89253e8b-9b3a-46f7-a4e9-ababf1d419bf
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 2.67 ms (jitter: 0.68ms, low: 2.35ms, high: 3.27ms)
Download: 280.91 Mbps (data used: 421.9 MB)
24.96 ms (jitter: 17.30ms, low: 5.28ms, high: 200.37ms)
Upload: 77.04 Mbps (data used: 83.4 MB)
273.15 ms (jitter: 74.42ms, low: 30.29ms, high: 647.80ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/ee9935cf-e5be-48d9-aa9c-feee7a4e84d5
The 5ghz setting of the HB611 router can enable up to 80mhz only whereas the 6ghz network can set 160mhz, is that something wrong?
Hmm, that does not match the spec published by TP-Link. You may want to post the screenshot. If you still cannnot get it to work, call Singtel 1688 for support.
https://www.singtel.com/personal/support/broadband/routers-ont/singtel-wifi-7-router-hb611-sgst
Make sure you update the FW version to the latest version as well.
https://www.singtel.com/personal/support/broadband/how-to-download-latest-firmware
HB611-SGST spec:
https://www.tp-link.com/sg/service-provider/wifi-router/hb611-sgst
11 Gbps Tri-Band WiFi 7: 6-stream tri-band WiFi 7
Signal Rate: BE11000,
6 GHz: Up to 5760 Mbps (EHT320)5 GHz: Up to 4320 Mbps (EHT240) --> should be okay to set to 160MHz channel2.4 GHz: Up to 688 Mbps (EHT40)*
Strange, just now saw the 160mhz appears for a while, after I set it and saved, it went back to 80mhz when I reopened the setting. Anyway I read online 80mhz is the 'correct' bandwidth for 5ghz network...
Need advises from those using HB611 here, what are your settings and speed?
