- Sep 16, 2018
I am dued to recontact in two months times paying $39 pm .
Should i switch or stay with Singtel
Usage requirements , One desktop with landline , and 3 phone using WiFi.
Currently linking
1. ZTE ZXA10 F620G
2. TP link home mesh WiFi system deco M9 plus
3.TP link AX dual band WiFi 6 router
Thank you.
1) The recommendation will depend on the details of your current setup and your preference.
2) You are using SingTel ONT.
Your existing wireless mesh solution (Deco M9 Plus) can only support 1Gbps. Do you use wireless backhaul or Ethernet backhaul between the two Deco nodes?
What is the model of the TP-Link AX dual band router? Do you use it as the main router after SingTel ONT?
How do you connect them?
3) When you change to other SingTel plans, you will need to change to use SingTel ONR. Are you using any special FW features of your main router?
4) Do you prefer to stay with SingTel even if you need to pay S$10 more per month? Or even S$20 more per month?
Basically M1 S$34.90 per month 6Gbps new user offer (with free Archer BE805) is of much better value than any SingTel recontract offer. Starhub S$29.55 per month 5Gbps offer (with free HB710) is also of much better value than any SingTel recontract offer. Both are using ONT.
