kimsix
- Jan 6, 2009
9x200mm radiator what a beast!
how are you temps now? how you rate the effort to set it up out of 10 to encourage more to join mora power?
btw you can also power the pump outside, using spare psu and 24pin jumper or paper clip!
I think just put DP today if you can run the system already, more time to live run and spot any issues over weekend! AC and Watercool are high end level with good QC expected
you should hoot astral now, hoot waterblock DHL in few days, and assemble everything final next week and report back!
https://www.aquatuning.com/en/water...re-geforce-rtx-5090-rog-astral-with-backplate
Think I can leave the GoChiller Prep-cool in there for a week until fittings arrive? or should I just put in Aquacomputer Double Protect Ultra in after few more hours?
