Anybody made Zeiss lens at JB Mid Valley before?
AlchemistJ19
few years back in KL mid valley, normal price + 200RM for carl zeiss lens.
But somehow the edges are blurry....
qw_er_ty
Wow just nice I am going to collect it later in jb. I bought rayban frame with Zeiss smartlife digital 1.6 refractive index lens with photofusion x. Total cost ard SGD 580plus.
First time try Zeiss also, hope is good. The optician told me that Hoya coating is the most lasting among all other brands but have a very obvious yellow tint. Zeiss is mainly for the technology and clarity.
PsyClick
how come the specs here so atas
my spec only $30 from foptics. the lenses make so much difference?
enimen
Just curious. Why you fixed premium lens in cheap frame? Won't it be wasted if your frame is broken earlier than the frame? Of course you can find the similar frame size if the frame is broken, but i remember quite troublesome and usually the optic shop keep pushing you to change everything.
Last time i choose branded frame like tag or ic berlin when i use it with zeiss lens.
I use cheap frame because the lens already very ex and I can't afford expensive frames too. So I will have to take good care of it to ensure they last...
Unclemun
Just did a set in KL, Zeiss ClearView Photofusion 1.6, 950RM for the lens.
Cheaper than in SG for sure.
How long do you need to wait to collect? Do you have to place a deposit and if so, how much?
SantyBalls
You under the delusion expensive frame = last longer?
orlengtao
My parents go there too. Used to go the bishan branch until the ladyboss passed away.
I always laugh at the ppl here buying so exp spects trying to justify their spending lol
i dont really like the people here though.
The frame everything is locked up, you take one, you have to put back one. I want to take a few and pick.. They scare people steal?
Also they don't tell you specific stuff and dont give you prescription. You have to ask clearly what lense & model for zesiss, what index, and what prescription is your left and right eyes. They dont give 100% though, the axis part they say is secret cannot give... Cmon lah i am coming back to you but at least be profesional. An optometrist should give you full prescription of your specs.
drkcynic
Cheap glasses I also have alot I just chuck them to one side usually. Are cheap things exclusive to you? Lol.
