[NEED EXPERTS HELP] Any most bang for bucks lappy can sic , preferably under $1K. But max budget notch more than $1.5K
tian_yibang
Yes
Also, nowadays Windows laptop got CISC and RISC chips. CISC cpu are your traditional Intel x88 instruction sets, AMD Ryzen are also CISC processors
RISC processors are commonly referred to as ARM chips. Snapdragon CPU etc.
They are not compatible with each other. Most Windows software in the world are running on the older CISC instruction set. Hence, if you buy the newer ARM chip, the old software needs to run under emulator
In short, if you choose an ARM Windows laptop, might as well buy an Apple MacBook Air, since it is also an ARM chip. You can run Windows through virtual machine and emulator
Fwah piang oi , this huan lagi more cheem
Moi ish lao unker noob on laptops , only know simi Intel/AMD/NVIDIA or i5/i7
Snapdragon tot only use on fones ?
:oops::oops:
cosmothecat
:oops::oops:
Oh no, things moving fast nowadays. Qualcomm snapdragon chip got laptop CPU version already. Kinda popular too, since it consume less battery, so longer battery life (similar to MacBooks M series chips)
cosmothecat
:oops::oops:
The listing below is a good laptop:
https://www.lazada.sg/products/pdp-i2960110098-s20358894451.html
Specifications of Asus 2023 MUX ROG Zephyrus G14, Thin & Light Gaming Laptop, 14" QHD (16:10) 165Hz Display, AMD Ryzen 9-7940HS, NVIDIA GEFORCE RTX 4060, with Cloth(32GB|2TB)​
  • Brand
    ASUS
  • SKU
    2960110098_SGAMZ-20358894451
  • Condition
    New
  • Display Size
    14 Inches
What’s in the box
Laptop
tian_yibang
  • Brand
    ASUS
  • SKU
  • Condition
    New
  • Display Size
    14 Inches
What’s in the box
Laptop
Fwah, moi really lag behind all these new laptops tech :frown: :frown:
Neway gaming laptop moi notch sho much into it, as moi only casual
Use gahmen "subsidy" to bai also must jaga abit , as moi still gotch other things to bai
:o :o
cosmothecat
:o :o
Oh, using CDC vouchers / SG60 vouchers to buy har? Then go Fairprice to buy.
The listing below is an Intel Lunar Lake CPU laptop. Lunar Lake CPU consume less battery, lasts longer on battery power.
https://www.fairprice.com.sg/product/acer-swift-14--copilot-pc--sf14-51-552k-ultra-5-intel-arc
$1399.00
Save $100.00Till 2nd Jul 2026
Acer Swift 14 Copilot+ PC SF14-51-552K (Ultra 5, Intel Arc)
1 S|Brand:Acer
  • • Intel Core Ultra 5 Processor 226V, Intel Arc
  • • 14" WUXGA (1920x1200) OLED, 400nits, DCI-P3 100% Display
  • • 2 Years Carry-in Local Singapore Warranty
  • • OB 16GB LPDDR5X RAM, 512GB PCIe NVMe SSD
ADDITIONAL INFORMATION​
  • • Windows 11 Home
  • • 512GB (552K), 1TB (534Z) PCIe NVMe SSD
  • • Intel Arc
  • • killer WiFi 7 & BluetoothĀ®5.3
  • • QHD IR Webcam
  • • Fingerprint Reader on Power Keycap
  • • 1.28kg
https://www.ultrabookreview.com/69679-intel-lunar-lake-laptops/
caterham7
  • Brand
    ASUS
  • SKU
  • Condition
    New
  • Display Size
    14 Inches
What’s in the box
Laptop
unknown shop, best to buyer beware
$1.5k not a small sum, safer to look at official asus store or reseller
tian_yibang
$1399.00
1 S|Brand:Acer
  • • Windows 11 Home
  • • Intel Arc
  • • QHD IR Webcam
  • • 1.28kg
Fwah, Ultra 5 ish simi lai eh
Also seems they only hab Acers , they hab simi "special" collab with them sibo
:oops::oops:
cosmothecat
:oops::oops:
Acers are usually the more affordable (read: cheap) laptop options
Ultra 5 is the latest Lunar Lake Intel CPU. It is more power efficient (consume less battery, so your battery lasts longer), and it comes with NPU to help AI software.
ferocity
Just becuz its listed on Fairprice online doesnt mean its available for sale at NTUC outlets. Fairprice online nowadays machiam become lelong platform like Shopee and Lazada where 3rd party sellers can list their products for sale and shipping and fulfillment are borne by the sellers themselves. And in this case for the Acer Laptop, its sold and delivered by Acer themselves.
BlackWing1977
Moi ish lappy noob, so quite dunno where to start from specs or function wise
So nong story short, any MS Windows laptops that "worth every cents" for a $1K budget ?
Preferably something notch more bigger than 14" as moi hab space constraints , and at least a 24/512 for futureproof use
Thinking wanna use the SG60V to get a lappy, but the Big 3 major stores and Challenger all dun accept so bopian later need use from GSTCash
What is 24/512??
BlackWing1977
TS got time go see see I remember got laptop under $1k for basic use.
Gaming laptop wise definetely above $1k.
Go for at least AMD Ryzen 5 with IGP will do for basic use.
Example this around $600.
https://www.harveynorman.com.sg/com...14-inch-laptop-green-grey-e1404fa-nk262w.html
Once you get GST voucher can just go buy.
Actually the RAM can upgrade or not.. I see the 8GB is like sibei ridiculous... bare bones minimum should be 16GB... sweet spot should be minimum 32GB
lalalalalala
if you ballsy can get from taobao, lenovo below 1k got 24gb ram and 1tb ssd
only thing is you have to flash english windows and i dunno about the warranty
Insatiable_creat
My partner just bought one Asus Vivobook Go 15 for $509. I just copied the specs and ask chatgpt to help me compare with the rest. Lol..
