HDTV talk - antenna and reception issues [consolidated]
tan1688
Just to check if the below antenna from china can be use in SPORE.
Link:¾*µäANT-407C ³µÔصçÊÓ DTMB CMMB DVB-TµØÃæ¸ßÇåµçÊÓÌìÏß-ÌÔ±¦Íø
I just given a similar omnidirectional antenna above to a bro yesterday for dvbt2 receiver testing, this type has got no directions might be better in a car since it is moving in all directions.
Below is a directional antenna, it is better can stick on back of car window or back of tv, or on window at home. I sell this on my thread
xjchew
Was looking thru GH antennas and fractal antennas.. Wondering if these two will be able to receive indo channel from a 5th floor hdb with them placed indoors. Anyone built one of these antennas?
Shion
Senior Mentor
Shouldn't be a problem. Why not you try it out? Ultimately, location is one of the bigger factor
Shion
Senior Mentor
Anybody can recommend the "BEST" analogue indoor tuner to tune into malaysia/indonesian channels that are within watchable quality?
You looking for the best antenna is it?
xjchew
Yeah.. probably going to get a balun, copper wire (anyone knows where to get 10AWG ones?) and some bolts to make a fractal antenna to test.
hwsinn
I need to get an antenna and hopefully its a passive antenna (not powered).
I read the mohu leaf 30 antenna is quite a good choice. however i find the whole thing too big and i was considering the metro but i would like to check with the bros here how this will fare locally?
I am living on mid high level and have slightly above average recep using normal V-antenna.
this is the Mohu metro:
Amazon.com: Mohu Leaf Metro HDTV Antenna: Electronics
yodajedi01
I got the MOHU LEAF 30 on my Dracon stb.
I'm able to receive HDTV from where I stay (Houang ave4) which will not be ready till 2015/2016
At first. I'm unable to receive any signal in my room, but if I stick it out of the windows,
WOW .... HD Channels
LxIxVxE
Senior Mentor
can get this paper thin antenna locally for S$25 with 1 yr warranty
seller claims it is comparable to mohu leaf antenna
real life performance unknown cos didn't buy
Antenna ANT-T19
White in colour (206 x 227 x 0.7mm)
Excellent reception for HD Digital TV signals
Ultra-thin and lightweight design
High tech design based on military application
High gain and low noise in-line amplifier
_21_zps538e6098.jpg~original
_20_zps7ce46e72.jpg~original
hosm
Bought the ANT-T19 antenna from Kaki Bukit.
This is an " active " antenna as it come with an amplifier housed in a small little box ( size of a disposable lighter ) that is powered via a supplied usb cable.
Installation is straight forward, however positioning of the antenna is needs for max signal strength. In my case, I can get reasonably good quality signal strength 1m away from the windows. This is compared with my passive antenna which I need to dangle at the window.
The attached antenna cable is rather short ( about 1.5m or so ) you may need to extend the cable run for better placement of the antenna.
HWZ1973
Really dunno wats MDA doing, having every flat to hang antennas out their windows???
Surprisingly you guys seems to be having a lot of fun....
Streetwise
U do know tat DVBT2 yet to rolll out for all of S'pore? Bros here eager to try out....so they are willing to experiment :D
sigur_ros
if i understand this right, once mda rolls out coverage island wide, the indoor antennas can remain indoors, i.e. no sticking out of windows and unsightly cables?
In other words, this is temporary.
HWZ1973
I really find this kind of implementation is so wrong...
Any other examples overseas?? Pls share...
Kiwi8
Deluxe Member
I'm not sure if that will really work for all households. Some households might still need to locate the antennas close to the window and that might be a problem for wives who are insistent on a tidy home arrangement.
hwsinn
So is it a must to use power if u want to operate the antenna? Is it able to operate passively?
hosm
I did a test without power, the signal strength drops quite a fair bit to about 60% , which cause the picture to break up.
Unless you are staying in area of good reception I would recommend that its better to run active.
Just plug the usb plug to your TV as it will turn on and off the power to your antenna as your TV set.
