renfred89
- Nov 11, 2007
I don't think so too. The mesh network abit chim.
Mesh network is mostly plug and play.. hahas
Meeth network is mostly plug and play.. hahas
there's two units for the Wi-Fi mesh.Don't tell me you mean home plugs everywhere.
Ic ya just read up. But how this device connects to singtel tv? Or singtel tv still needs to connect to the main router?there's two units for the Wi-Fi mesh.
The first unit - you need to connect to the router (hence it must be beside it).
The second unit - place it in your bedroom or study room for extended coverage.
http://info.singtel.com/personal/wifi-mesh/faq
doesn't seem complicated or chim from this FAQ.
so like what you say,nope, singtel tv goes straight to the wifi mesh node. basically the wifi mesh needs 2 nodes to work. one node goes to the router and another node can be placed anywhere within the coverage of the 1st node. once the 2nd node established a secured wifi with the first node, it expands the coverage as well as supporting singtel tv.
so in a way, singtel tv streams over wifi from the first node, if the stb is connected to the 2nd node. even if singtel tv is operating, the 2nd node can still act as an access point for other wireless clients.
45 degreesyou are talking about ac5300 or ac88u?
if you are sure its ac5300, then may i ask how u position the antennas?
1st node (2 ports) 1 port must be plug in to the main router (Asus any port?)
2nd node (2 ports) 1 port plug into STB, the other port can it be plug to other device to receive internet? or to AP / switch for broadcast or multiple devices? or it can also act as an AP but not sure what is the coverage.
Will there be drop of speed?
Icic Ok....If u intend to use wifi mesh, you cannot use ac88u as the router. Anyway, if u intend to use mesh, then u can keep your 7009.
Wifi mesh works best if ur router has wireless turned off.. this way the mesh will not compete with your wireless router for airspace.
If u intend to use mesh with ac88u, then the mesh is useless cos u can either choose to use the mesh for internet, or singtel tv, mutually exclusive.
Otherwise assuming you are using with 7009, then the above u wrote is ideal..
Got the RT-AC88 to try out the link aggregation with the Synology DS716+
Also got the Emerson Liebert UPS 600 as it ha a USB funciton to tell the NAs to shutdown in case of a power outage.
Just Gotten the RT-88U. Was an old firmware. Btw guys, do i have to restore to factory defaults after updating the software? The router did an automatic update for me. And if i set the Tx-power low, will it affect any performance?
- Recommended to do an restore to factory default after update.
- Lower Tx power will degree the wireless range and it might affect the wireless performance if your wireless device is far away.
Okay thank so much! Then any recommended settings. Planning to use my RT87U as an Access Point. Could I use the same SSID? And does both the router comes with the free Roaming thingy?
Thank you very much! Noted! Btw, can anyone advice on how to hang against the wall? Cause I find out that the design of the base is different from RT87 as rt87 I can hang it against the wall
