What for?!
So close proximity defeats the purpose
Sent from Google PIXEL XL using GAGT
Because all new bto. Telephone line can convert to data port. So all can be connected to the wifi mesh
What for?!
Can, wired backhaul will always be better if you can do that.
I have all 3 types of WiFi Mesh that Singtel offers.
My favourite is the Samsung WiFi Mesh because i make use of the Smart Home functions.
Is the Askey one good? Think of going for it.
Does samsung connect home support wired backhaul?
My airties set is acting up.
Turned it off over the weekend as was away. Came home, turned on and the 5Ghz light continuously red now.
Did not shift the units whatsoever. Tried rebooting both airties units. At first, it blinks green on the 5Ghz and then goes red eventually.
There is line of sight between both units and despite the red light, I can still surf on the 5Ghz band.
So, does this mean the unit is failing?
Hi trickle_on,
Can you try moving the two units closer together to see if the light returns to green?
Solid red on 5GHz channel indicates that the wireless connection between the two units is weak.
Thanks for the suggestion. I've placed the units right next to each other and the 5Ghz indicator still blinks red.
Maybe it's due to 5Ghz interference?
Perhaps you can try resetting them?
Hello guys,
Dont mind me posting here uhNeed some advice from the gurus here. I'm currently on Singtel 1Gbps plan.
Here's the speedtest result (from speedtest.net) that I got:
Download: 290.42Mbps
Upload: 213.94 Mbps (Couldnt post link since i'm new)
This result is run from my computer desktop.
1. My computer is connected to my 2nd unit of Askey wifi mesh via ethernet cable (cat5e)
2. My 1st Askey unit is at the living room and is connected to the Aztech router (FG7003 GRV - J).
3. Both the 2.4Ghz and 5Ghz lights on the mesh are green and stable.
4. I have turned off Wifi on my router in case it interferes with the Mesh units.
5. My computer has Gigabit port and theoretically should be able to support the speed.
So my question is, why am I only achieving this speed? Any suspects of where the bottleneck is? I recently just checked the hardware of Askey Wifi mesh units and it appears that the LAN port is 10/100Mbps. Could this be the culprit? Hope to seek some advice. Thanks in advance guys!
LAN port of askey should be gigabit.
The bottle neck is between the askey nodes. In wifi, there is no way you can achieve close to 1gbps over wifi, especially on mesh systems. You can try bringing the nodes closer together, the system will automatically select a better channel for the wireless backhaul.
Hi all,Hi, may I have AirTies firmware update please?
Can AirTies uses different SSID for 2.4GHz & 5GHz?
Thank you![]()
"Until your post count is 10 you will be able to send PMs to Staff only"
We just renew our plan, thought Singtel will give onr & new router but Singtel shop asked us to reuse old ont & router, very upset. My brother new house got onr & new router, we planed to connect AirTies & PC directly to onr, can we request to replace our ont with onr?
Thank you.
Hi, we are using FG7009GR(AC), thought will be given a AC Plus by Singtel like my brother house, too bad don't have. Btw, we are using ZTE ONT, are there any other ont model which can support LAN ports 2 - 4? Thank.
