Sonoff switches can be hacked to localise the scheduling. But do take note that these Sonoff switches need neutral wiringThanks. I just need to have a 2-gang light switch that I can schedule a on and off timing daily.
which is my main obstacle...my current light switch do not have neutral...
So if I just need smart light switch that allows me to put in the on-off schedule, can I use the TC2 light switches? These must go through the Broadlink RM-Pro?
You intend to use only 1 gang out of the 3 gang to control the 2 X 60w?
If yes, can consider etouch switch. Max 150w/gang.
Sent from HUAWEI BLA-L29 using GAGT
1. You might want to get a RF socket like this to convert a dumb power strip into a smart one.hi all, planning to get the RM Pro+ for my new home and been following this thread.. got a few questions, hopefully can get some advice:
1. anyone using a smart strip / extension power socket that's compatible?
- broadlink has 1 but don't have our 3-pin type, so wondering if anyone has success using other brand ones.
2. i have a 14m long LED light strip that i intend to run around the living room like cove lights. the smart switches like the Broadlink TC2 seem to have limitation on the max load per gang of LED Lights at 100w.
- will there be any issues if my 14m LED light strip exceeds 100w?
- if so, any other recommended smart switch that's compatible with RM Pro+ that doesn't require a neutral?
- saw the previous post recommending the etouch switch, think 150w may not be enough for my 14m..
Thanks in advance!
how do you guys live using livolo without status feedback? been bothering me for the longest time using broadlink.. thinking if I should switch to xiaomi ecosystem.. else, most of time broadlink is nice, works well with alexa via bridge
You need to calculate or ask electrician what is the power consumption for your 14m led strip first.?hi all, planning to get the RM Pro+ for my new home and been following this thread.. got a few questions, hopefully can get some advice:
Thanks in advance!
https://m.qoo10.sg/gmkt.inc/Mobile/Goods/Goods.aspx?goodscode=443148675
2. If the drawn power exceeds the power rating, you might cause the switch to be fried and this is a potential fire hazard.
Will changing to xiaomi ecosystem solve this feedback issue? No doubt that there is one Aqara switch without neutral, but without neutral wiring, how to get the feedback? Having status feedback is a good to have for me... Worst case I execute the command twice or fire the command indiscriminately. Anyway, for lightings, there is always visual feedback![]()
Guess TC2 switch is still the best then.. xiaomi has a wider range of devices to try though, broadlink has been the same for the last few years. sometimes would like to turn on the lights when on holiday etc, useful if can see the feedback..don't have an IPcam installed in the home, dont know who might be watching.. haha
I'm using funry for my new place. Used for 1month. So far so good, although a few of the lights require the capacitor provided to be stable.Anyone tried using Funry switches with RM pro? They are much cheaper than TC2 and also do not require neutral line.
My rm pro is working well with my kdk ceiling fan. My kdk is using IR to control so have to be line of sight.Hi, I am about to get rm pro +, can I confirm with any expert here that RM pro+ work with KDK ceiling fan?
And TC2 switch can connect to KDK ceiling fan since I see the specification cannot exceed 100w?
Thanks.
I'm using funry switch and it's working well. Not sure about TC2 sorry.
My electrician installed. My kdk ceiling fan doesn't require capacitor.Thanks for your reply,if funry switch is working fine then I may go for it too, but I saw your reply that it need the capacitor ? So you have to add capacitor yourself ?
