e-Remote Broadlink RM-Pro
infernolord
Hi anyone has issue with broadlink air-con smart device with Echo? My amazon app suddenly change all broadlink air conditioner as thermostat. This has create issue with routine as i cant turn on or off, can only adjust the temperate via routine.
Anyone has the same issue?
infernolord
Anyone has tried a smart switch that works with this?
Smart Glass/Film
https://reveil.sg/project.html
http://www.privacysolution.com.sg/
Try to diy myself on a mirror.. fail badly.
U can try get from tb, they can custom the solar flim for you. It is remotely control.. ie can use your broadlink or rf blast to control.
Problem is that, you really require a professional to stick it on your glass. I tried, alot of water mark and bubbles.. super tough to do it.
ckone
Anyone using smart bulbs with RM-Pro+?
Saw that Broadlink has bulbs on Taobao but like can't buy from SG and nobody else selling leh..
Elon Jobs
Broadlink SP2 $16.20 after 20% discount inclusive of shipping. 2 hours left.
https://shopee.sg/longtong.sg/1415349653
R4stafari
Can it be installed by spraying some water on the glass then use a squeeze? Using the water should eliminate those bubbling...
apengrg
My Broadlink RM pro+ seems to hv weak IR. Broadlink needs to fire the ir a few times by repeating my voice commands to Google home. Anyone?
medscy
First of all, IR needs line of sight. Is there any blockage?
Secondly, did u try using the iHC or EControl app and does it yield the same result? There are more delays and points of failure from Google cloud -> Broadlink Cloud -> your rm pro
shacboi
Any of u using IP camera which uses SMART Life / eWelink app? Or know any IP camera using that app, cos I wanna get one that can integrate with IFTTT to trigger broadlink when motion detected for example, thanks in advance! :s13:
apengrg
Right bro, commands lost in the clouds :s22:
medscy
I hv GH and Broadlink. Shd I get Sonoff RF or Sonoff basic?
None of the above... Sonoff basic is a esp8266 based wifi switch whereas sonoff rf is a esp9266 sup up with rf radio. Sonoff RF is an overpriced rf plug due to the esp8266. You will b better off getting a normal RF plug.
I have 3 brand new spares that I can let go for $7 each. They still come with 1 year warranty with the local dealer. pm if u r interested.
singcheng
Why not Sonoff S26?
I bought from Taobao for rmb50+.
【Sonoff S26 易微联Wifi智能定时远程开关智能插座 英美欧澳CN规】https://m.tb.cn/h.3FRHZPo?sm=6c44a2 点击链接,再选择浏览器咑閞;或復·制这段描述¥KXEHbGev6MR¥后到👉淘♂寳♀👈
Posted from PCWX using phone.
Creator of OEM Comparison Chart & Plan Calculator.
Ohm user since April 2018.
rochmer
For s2 broadlink motion sensor, after it detects motion, it does not detect anymore until like 10min later. Why is this so?
singcheng
Sorry I didn't make it clear. I'm looking for a switch not a plug.
Oh, i am using this WIFI switch. You need neutral line for this.
【智能家居wifi手机远程无线触摸钢化玻璃面板86零火线单控定时开关】https://m.tb.cn/h.3F9iqZQ?sm=6e8bec 点击链接,再选择浏览器咑閞;或復·制这段描述¥ClNFbGUKZJw¥后到👉淘♂寳♀👈
medscy
If you are looking for RF switch, you are spoilt for choices... There are more cost effective solutions like Funry, Yoogee or even the native Broadlink switches. Sonoff is good if you are running a mqtt backbone. If you are going to use the ewelink ecosystem, then you will have to integrate with Broadlink via IFTTT.
My suggestion is to keep it simple.
rochmer
Go to settings under delay time and change.
I tried everything but still same. Until I had to try changing the jumpers inside the sensor, then it at least lights up when there is motion.
Actually whats the delay time for? I tot it is to delay the detection or delay the alarm from ringing?
Elon Jobs
Delay is the gap time between the sensor activating.
To delay the action, it’s “hold time”.
