Engine oil to recommend
CCCustom
I'd say use any of the "mid-range brand" synthetics at 30-weight, but buy them only then there's a GB on your car club, or when they're on sale in Giant (Mobil1).
Redline, Amsoil - around $16 per quart during GBs, if you buy the gallon it's usually a little bit cheaper.
Mobil1 - I don't know if there are still $9.95 sales like the old days. People who shop at Giant SWEEP these by the boxes once they're on sale.
eurofunk
i tried both liquid moly and voltronic...both also okay to me...just that difference of abt 50bucks only
voltronic seems to maintain lower oil temp though
AL5509
Didjerama; said:
I avoid
Shell
KIC
May I understand why not SHELL?
Think some AD using this if not wrong.
Cannot be asking them not to use it or can we?
tmfwy
Liqui Moly semi syn 15k change
Castrol semi syn < 90rm 10-12k change
Petronas nice but ex unless offer.
I avoid Schaeffer / Carlube
Must change at 5k interva coz max is 7.5
Change at 10 is very dark......
CCCustom
Kah Motor uses Shell, I bring my own oil and save ~$50
Quite a number of ADs use Shell. :o
That is what I understand too.
So why not use Shell when Quite a few ADs using I wonder?
I believe it's a bulk or contract arrangement between ADs and Shell, not that it's the best for their cars.
Apart from the fact that you'll be paying about double the price using AD-supplied Shell (you can pick up a gallon of Shell oil from supermarkets for ~$50+), it's 5w40 and not the optimal weight oil for most modern cars ... e.g. almost all of the current Hondas (except the Type Rs) are specced for 20-weight oil (although most folks will still use 30-weight for "added protection"). Using a 40-weight oil will affect your FC.
AL5509
Thank you so much for sharing the technical knowledge.
I do understand it may not be the 'best' EO used but as those brand new cars service under AD will need to stick to AD.
For example: Need to service for 3 years / 60,000km mileage.
Hence, having not to be the 'best' EO used.
Will Shell affect the engine?
tiffanydunk
wah my last service i swapped over to Shell helix leh. Previously on liqui moly. So far ok leh.
Dragon
Administrator
Shell EO is decent lah. The engine won't explode don't worry. Better to use a decent EO than not doing EO change regularly. Ferrari F1 also use Shell. :s13:
EEXOOO
Shell is okay, thing is it's w40 and it's expensive. Mobil 1 when on promotion are around 9.99-11.99/quart during promo while IMO feels better than Shell.
Flexamoria
I'm using this now
pew
The explanation I heard for using 40 oil instead of 20 or 30 is because engine wear is higher in sg due to the stop-start traffic conditions here.
playstation76
Shell EO is a good oil. Shell has a good reputation worldwide
