Fuwell, total disappointment.
Limexx
wa lau eh... Your English even more hosei!
"can't won an argument" ?
LOL
Err... So you and that RichLiao clown are classmates? Which school? Maybe even using the same terminal or same account. Who knows. Both machiam same standard. :s13::s13:
yes bro this threads becoming grammer and spellings editings threads liaos. please helps me edits moi grammers, moi 0 levels editing failz
moi say moi from NUS u belive or not. I can says I from any schools mah, you from which schoolz?
Richliao
silverhawkeye
Idk but aftershock does this too right? But the difference is they're a boutique desktop brand and Fuwell isn't lol
Yes. Aftershock does that too. Even cables and screws will not be returned to customers unless they specifically ask for them.
silverhawkeye
I think Apple is better than Google, should I goes there to work too :vijayadmin:
Of course u are qualified! I believe big companies are always in need of trolls for online disinformation. You are a rare talent for that purpose.
Navillera
Wow this claim I triggered :s13::s13:
Have you attempted to play at 1080p on a 4k monitor before? From personal experience? How was it like?
Me back then as a casual gamer having used a 4k@60hz monitor (Dell P2715Q) on a GTX 980Ti would disagree with both statements :s13::s13:
Have you gone through the pain of turning down the resolution on a 4k monitor before to game, only to realise that turning down the graphics fidelity of the game and staying at native resolution would be a better overall experience (i.e. not as pixelated)?
Precisely. Not sure what he’s smoking
Cedesria
Not sure if you were referring to this tall and skinny guy (about 175cm) and wears black-rimmed glasses?
Anyway, I went there to enquire about monitors. He told me IPS monitors are never curved and only VA panels are curved. At that point (having owned the LG34UC79G which is a curved IPS panel), I immediately knew he was sprouting garbage.
The next moment, he told me my video card (RTX 2070s) will not be able to support games at high refresh rate and 2K resolution, so no point buying a gaming monitor. LOL
Does he not know that most people typically do not play games at native resolutions. Most casual gamers play only at 1080p, albeit at high refresh rates. A modest mid-range graphics card can easily support that. And many people who get gaming monitors want to enjoy the high-resolution in productivity/office work and at the same time, high refresh rates for the occasional gaming.
His point is that if you get a 2K monitor, you can only play games at 2K. :s13:
Anyway, after I stepped outside, I took a look at the shop's name and rolled my eyes.
Nope, its a tall guy not wearing specs. Talk like ah beng, tmd he dunno uncle me last time is ah beng.... but just that I dont need to bring myself to his level la.
silverhawkeye
So you bought the 4K@60Hz as a casual gamer? I kinda understand your experience. I will not even game on such a monitor. First, playing at native resolution of 4K and then cranking down all the details in-game simply defeats the purpose of having a 4K monitor in the first place. Second, playing games (especially fast-paced FPS) capped at 60Hz is a thrust back to the era of Command and Conquer (pun intended). Worse, you may also observe screen tearing, which happens when your graphics card is rendering frames faster than your monitor can display them. You can of course enable VSync which caps your frame rate to 60fps, but you’ll get a higher input lag which truly sucks for an FPS. In any case, I will not advise playing fast-paced FPS on a 60Hz monitor, much less at 4K native resolution. And your GTX 980Ti obviously isn't an ideal card for 4K high frame-rate gaming.
It's debatable which is worse: cranking down all in-game details at 4K native resolution OR playing at lower resolution with a far smoother experience and with the highest in-game details. :s13:
silverhawkeye
People said better than...you know what that means? You know what 'than' means?
And if he thinks Aftershock is a better business to patronise means must join as staff? You smoking what?
What talking you? You want to write in your native language and let me do a Google translate? Believe it'll be easier for me to understand.
silverhawkeye
then we are likely referring to different guys but then that only shows their level of service in general. To be fair, the guy who served me was trying to put on an appearance of sophistication but maybe he tried too hard and I wasn't just some gullible average consumer who knows nuts about tech.
ragnarok95
Senior Moderator
Senior Moderator
Speaking from a casual player POV (me).
When you install window, window will usually default to the best native resolution available. A casual player will just install the game.... and just run it. Correct me if i'm wrong but games now a day will just run at your native resolution your window set right?
soltrdc
Many games these days do a self-optimization on first start up. It selects settings based on, I believe, target frame rate (defined by the software), and available hardware. Hardware includes the monitor (available resolutions and refresh rates) and GPU capability. So answer is yes and no - it depends on software optimization.
backup_account
I'm a casual gamer who plays occasionally at native resolution with a RTX3090, I believe it is the same for most people if not for the lack of stocks recently. In fact every gamer that I know plays at native resolution.
congster2
Yeah. At lower resolutions, you might run into pixel mismatch issues too. It won’t be as nice.
soltrdc
Not gonna generalize, but here's my pov
I bought a 27" monitor for the real estate. It helps when working to have windows side by side instead of always alt tabbing.
Since I use the monitor at home for personal use as well, I got a 4K for streaming 4K videos.
When it comes to games, since I have a 4K monitor, I do expect to make full use of it to play at 4K. I can accept lower resolutions too, due to hardware limits, but it's more of a compromise rather than targeting to play lower than native resolution.
