Galaxy Note 3 4.4.2 Kit Kat update
gamma7sg
Kitkat is bad..
Clipboard is gone from keyboard..
My apps now become buggy..
Anyone guru here knows how to downgrade back to jelly bean??
'By right', once you upgraded to kitkat, it is not possible to downgrade to jellybean... dunno is there any 'by left' method....
lxb_70
updated to NB4! batt seems same or even better! no batt drain
Bonn
Do you guys have GPS problems? Seems like after the last 2 updates, my GPS cannot get any lock. Its like something interfering with the GPS software/hardware. Hmmm...
renfred89
My gps works fine. Make sure your GPS setting is not set to power-saving mode.
lxb_70
Found something... b4 NB4, i use my note 1 charger to charge, can, normal speed... after NB4.. i use the same charger to charge.. 1 and half hour only 6%! Jialat.. will monitor again tomorrow as the note 1 charger was in my office. Use note 3 charger no problem.
Johnteoh
Not sure this App will help on the file saving to SD card, this App is like Task on PC, which purpose is to move files or folder to SD card.
For today (27 Feb) only you can unlock the Pro version for free.
Redirect File Organizer
More than One (Re)Direction
Free + bonus : $1.92
★ to unlock Pro version > settings (menu top left) > unlock Pro version > promocode: appgratis (one word) ★
When you were a kid, there was your mom or dad to make you tidy your room. But you can't depend on them to hassle you to keep your smartphone in order, luckily you have me!
Me and Xavier, the developer of Redirect File Organizer, a unique and ultra-handy app that keeps your phone organized by managing your files. Set up automatic redirects (move photos folder to SD card, move videos to a specific folder...), redirects are easy to undo, and the tutorial helps you get the most out of the app. Unlock the Pro version (more themes, more options), worth $1.92, but FREE today!
https://play.google.com/store/apps/details?id=com.tobino.redirectsfree&referrer=utm_source%3Dappgratis
Tired but not working. I really starting to think Google is trying to piss people off to use iOS with this restriction.
samgoh87
Clipboard can set back de. Just press and hold the left or right button next to space bar, then choose clipboard lor..
jim123
After updating to the latest FW yesterday, I forgot to charge the phone when I went to sleep. When I wake up, I was pleasantly surprised that the battery dropped only around ~2% (the battery % line was quite flat from 11pm to 6am).
Did you guys do a factory reset after upgrading? My battery drain seems bad. Went to bed last night at 11.30pm batt=30% and this morning 7.30am left 4%....:eek:
nobody44
I did a factory reset. 3% drop over the night...
shichuanhua
Problems are completely random, certain ppl works perfectly after update, some won't . and factory reset NORMALLY solve all the problems
agoodfella
Does anyone else use Business Calendar Pro?
After the KitKate update, the calendar event notification cannot be cleared in the pull down menu.
Anyone else experiencing this issue?
Thanks!
Lucky123
After updating to KK so many problems for me. Factory reset until sianz (even total wipe out at service centre) and problems still persist. Now got a full motherboard change and found that the firmware is back to JB....and good thing is now everything is working fine like it used to. Scared liao not updating anymore.
