marcus70
- Dec 17, 2006
I think he meant the newest firmware update that fix 3rd party Sview
ok thks,as i db my fw from sammobile not through ota wondering they have the patch or not
My gps works fine. Make sure your GPS setting is not set to power-saving mode.
Do you guys have GPS problems? Seems like after the last 2 updates, my GPS cannot get any lock. Its like something interfering with the GPS software/hardware. Hmmm...
Updated to both the 4.4.2 and the latest KK patch. Happy user and no issues.![]()
How about the external SD card issue?
Where to get the patch?
huh? so fast? what the diff?NB5 is just out....![]()
I also don't know ba. ..
It is for Hong Kong at the moment, not for Hougang. ..
The patch is only for rooted phones.
what patch![]()
What I'm referring to is the 2nd KK update and not patch. Sorry to have created any confusion to anyone.
As for the SD card issues, I actually have not check it out. How do I check it out?
it seems those 3rd app need to access the ext sd card will not work,if your phone r rooted,check whether you can do backup to the extsd card using titanium backup...for mine after updated to kk,the backup won't work until i applied the patch then it works again
