Galaxy Note 3 4.4.2 Kit Kat update
Lucky123
just curious, what are the problems?
Some of the common issues here like the SD card, retarded clock widget, lagging especially the lock screen key pad, battery drain etc
Worst of all Wifi saved settings keep getting reset and wiped out for no apparent reason. This I can't live with coz I have many APs and imagine I have to key in each and every one of them every time the data kenna wiped out.
So far I only see complaints at KK.....yet to find anyone reaping any benefit from it.
ATN888
Thanks for sharing, feels your pain. Guess could be a blessing, maybe your MB was already failing before upgrade & all hell broke loose ... at least you've got a new MB and back to good old JB4.3.
Mine so far seems ok except the external Sdcard issue. Able to deep sleep with no major drain. Only difference I see on the battery usage ... Android System (>20%) is now on my top 3, used to be at the bottom of the list at <10%. What are you guys seeing?
iguoh
After reading so many complaints, I am thinking I should not update to Kitkat. I have Kitkat downloaded but not installed. I keep getting prompted to install the update. Is there a way to remove what was downloaded and stay with Jellybean?
renfred89
Uncheck auto upsate option from software update.. that should delete the sofrware..
bobosooter
I just updated to Kit Kat last night and now my Note 3 goes into a power down & reset loop! Sianzz! :(
ATN888
ATN888
can try clear cache and data from settings>general>appmgr>all>softwareupdate
then remember go back uncheck the auto update
tingyuan
battery drain so fast, is it abnormal note 3 getting hot while charging?
teoph04
It seems that after the update, battery is draining more than usual...
Anyone experiencing it?
Lucky123
Seriously after mb change n back to JB battery life is back to normal. Now I can leave BT n GPS permanently on without worry of power drain. With KK,couldn't do this. Now considering how to get my wife's unit back to JB. No more useless updates for me.
