Galaxy Note 3 4.4.2 Kit Kat update
kelvinti
How to turn off the shutter sound? No option in camera settings leh...how to shoot meimei in discreet like that? lol.
Too bad!:(
No option to turn off shutter sound!:o
The only way is too mute your your phone!
The camera can be muted using Enforced Stream Silencer, without impact to other audio function.
Google for the APK and side load it to the phone.
This work for me when i take photos no shutter sound but, have to disable it when listening music ....
HERE
CrimsonLotus
This is dam mad till today still can't get any update for the Kitkat version..
been trying since Friday still no sign for update :( Keep on press for update
nothing it only show "you have the latest version" this is real mad.
Same thing here. -_-
Everyone seems to be able to update except me. Pekcek max.
mr_voodoo
I could not get the update via wifi as well, kept pressing check several times.
Switched off wifi, and used 4G to check for update and got it immediately.
and then when it started to update, I switched off data and select update via wifi only and switch on wifi. It continued downloading the update.
lawlaw77
Do anyone face Bluetooth connection problem? I cant paired my bluetooth headphone with my note 3..
Leonard_Ong
If you have not updated, please consider holding on.
External SD access is restricted. I have some apps that won't work as they need access to external SD e.g. Sygic.
gt_5454
Upgraded my wife's note 3 to KitKat and now having severe battery drain. Charged till 100% and barely use it. 5 hours later battery left 40%. Updated using OTA anyway if it makes any difference.
I know its good to reset and reinstall all apps but is there other ways as to set all the ringtones, alarms , wallpapers are very tiring.
Thanks in advance
agcken12
Wallpaper will be back automatic come back once restart. Ring tone n alarm have to re set again.
berzy
anyone face problem with auto brightness after upgrading???
seem that my auto brightness not working after upgrading to kitkat.....
battery seem to drain a little bit faster too
:s22:
kelvinti
:s22:
if you don't mind. Do a factory reset like I did since Kitkat is considered a major update from Jelly Bean.
I'm facing no problem or whatever sorts at all after performing a factory reset. :)
twosix
I guess sometimes updating the FW depends on luck. My note3 works normally after KK update.
kiwitan
Bluetooth earpiece unable to pair with Samsung note 3 on 4.4.2.
External sdcard unable to be written too.
