Huawei Mate 10
piyozz
Cannot also. Need to manually enable the other sim to get data from other sim. Btw, when u enable dual sim 4G, does both ur sim displayed 4G at status bar? Mine only TPG 4G even though both also set to auto, G/WCDMA/LTE.
Same :( so I didn't feel there is any diff whether it's set to dual 4g or not.
j4nfz1981
I just realised if i disable my TPG sim totally and enable only my original sim, enable 4g n data. Like usual, i c 4g. But once i disable data, 4g icon disappear. That make sense to me y i only c one 4g.
Same as in only one 4g display?
raintr33
After my upgrade, DBS banking apps is now unable to be screenshot. Anybody had this issue too? Any workaround as screenshot is useful to capture evidence/details when transferring fund.
My current workaround is to login from website to get the details :-(
amazingone
I still can take screenshot in the posb digibank app
Posted from PCWX using HUAWEI ALPS
piyozz
I also can still do screenshot. Am on the latest version of posb app
Shib
Use the screen capture from the drop down menu?
Sent from HUAWEI MATE 10 using GAGT
raintr33
Thanks guys... guess its only restricted on the DBS iWealth apps then :-(
My OCBC apps can also be screen captured.
Thanks for trying on your phones.
Shib
Uob has this restriction but they have a save to gallery icon. Dbs should have similar too.
raintr33
Boh leh, don't have such option.
Need to feedback to the developers.
Posted from PCWX using ALP-L29
OutBreak
I am still able to screen capture.
OutBreak
I was about to ask about this too. Just updated to v159 on non pro. Noticed my battery draining very fast. Wanted to find the location to see if it was set wrongly. Can't find the locating method icon too!
I think battery life is still great.
TheOutsider
Are you using a sinktel router? Haha.
I have S***hub wifi and mobile.
When I was still on Sinktell mobile at least I still can switchover. So regret changing to both S***hub.
Now both is doing real bad. S***hub getting worse. Now on wifi sometimes even youtube won't run smoothly.
DOINK1
All is good for this phone (mate 10) except it is unable connect to hidden WIFI which open a browser to require username and password. Can't even connect to overseas Hotel WIFI... haizzz
Ruriel
Why unable? I can connect to such WiFi with no issues at all. If your browser for some reason can't be auto launched, then you manually launch it yourself. Browse to some website like hwz or something and the WiFi which you are trying to connect will redirect you to their login page.
