Huawei Mate 10
progene
Help! Anyone knows how to turn off the step counter (numbers of steps taken) on locked screenfir mate 10?
I tried turning off notifications for Health, hicare, can't seem to find the right one....
Sent from HUAWEI ALP-L29 using GAGT
r0_ger
Becos you are smarter than the phone :)
Auto brightness requires the use of sensor to detect the light hence it will drain battery.
The only down side is if you set it way down and go under the sun, you might not be able to see the screen. Unless you are constantly in and out of office, auto is really not necessary especially if you want to save a bit of juice
Can save how much more?
keith00
Was trying back up my phone using hi suite. But it's don't seem to back up music and photo??
OutBreak
Does anyone know when is the deadline for this free gift? I bought from M1 say like 2 weeks back.
Today should be the last day for the Nex roadshow. You can purchased the phone from any Telco at NEX to redeem it. Check with Huawei whether you still can redeem it.
deckcard
Was trying back up my phone using hi suite. But it's don't seem to back up musc and photo??
After u connect phone to computer via USB, click MTP option on the phone (drop down menu option), the phone will show up on ur PC as storage. Just go to the folders and copy the files your computer. Simple don't need to use hisuite
Zappalapa
Anyone knows whether secret code works on android oreo?
wanna do some tests like screen/sensitivity tests on dialler pad but nth happened after typing the code.
potatoinapot
why u guys don't use auto brightness? i tot it's the smarter way to conserve battery since it'll set the brightness according to the surroundings, instead of consistently bright. am i missing something?
Because I don't like the screen brightening and dimming.
kimsix
The 10 pro screen looks incredibly lowres to me. Pentile oled cannot stay at 1080p imo.
Can the m10 make volte calls finally?
arbok26
1st Post here though I registered 2 years ago :)
Well 1080p still has a pretty high PPI (400+ I believe), unless you're using it for VR, its not going to be that bad imo. :)
Secondly it'll be better for games with the lower resolution as the GPU doesn't have to pump out that many pixels. The Lower Res will help your phone last longer imo.
If I had to choose the OLED on the Mate 10 pro vs the LCD on the Mate 10, the OLED looks like it has a wider spectrum of colours (Colour Saturation: 112% NTSC vs 96% NTSC), and it'll make your photos look great on screen.
muddle
Fyi note 8 defaults to full hd res out of the box. Not sure if anyone ever notice that.
OutBreak
I'm surprised there are not much bloatware. Only the Facebook and Quik cannot be uninstalled..
