M.2 NVMe storage Recommendation
harky
the sn770 if i am not wrong does not have dram..
if for main drive i would spend a bit more..
but if for game drive or 2nd drive then i think u dont need to pay so high...
what the dram thing?
850?
wongminmin
thn u convert local warranty?
Does it show "Out of region" when you register it online?
If yes, the online RMA form may not let you proceed and you have to contact WD support to process it.
Once you have the RMA number, give the RMA contact number a call to ask if they have the stock available for on-the-spot replacement.
If you need to RMA, you can contact WD Singapore cust svc for an exception to allow local RMA. I've done this a couple of times for HDDs and WD has always been very accommodating. YMMV
deepblue_82
for main drive its better to go for something with d ram.
for 2nd or game drive for me i think cheap cheap is ok already
anyways now games almost all 100% online already so there is no local save files.. so if it dies its still ok
harky
if u want to go for sn850 i would rather u go for sn850x for 1 tb
but if u looking for 2 tb then only can see how much are u willing to pay
wd 850 must get from local.. amazon price is too ex
and why there is non-HEATSINK & HEATSINK??? make life so hard
kaixax555
Not all M.2. slots on all mobos come with heatsink
Gen4 drives can get hot so heatsink can help it run at higher speeds for longer
If your M.2 slot got heatsink then just buy the non-heatsink version otherwise get the heatsink version (though SN850X heatsink feels like a ripoff)
wongminmin
higher transfer speed, more heat generated, lifespan also reduced.
most mobo come with the heatsink.....else u can just buy jeyi heatsink for few dollars.
deepblue_82
90% of the mb out there the main mvme drive will have a heat sink but the 2nd slot will not have only very few..
deepblue_82
or then is 1 last way is... main drive use nvme then 2nd drive use stata cheaper and no need heat sink...
yes stata is slower but still can game well...
gpgtmeowmeow
Yes, SN770 is dram-less, but uses hmb instead. That is one of the reasons why it is cheaper.
I still think the SN770 good purchase if it is within your budget.
It is perfectly fine option for anything as long as not for write heavy operations.
Otherwise top up a bit more for 2TB SN850X also nubbad hor.
SN850X (Amazon.com)
217.80, checkout price 246.82....
