M.2 NVMe storage Recommendation
Dashie
Hi I would like to ask if my old AMD motherboard TUF B450M-PLUS will be able to use a second NVME SSD if I buy a second one of any Samsung EVO M2? thanks in advance because I know next to nothing about this but I want to add another NVME M2 for storage.
ragnarok95
Senior Moderator
Senior Moderator
Your motherboard only have 1 nvme slot.
xonix
Since your board only has 1 single nvme slot, the only way is to buy 2.5" SATA ssd or pcie-nvme adapter
s-zoom.file
Dashie
s-zoom.file
Thank you guys for the reply! I would prefer the adapter to use NVME Is there anything I should look out for while buying the adapter? which one would you recommend to get?
naked123
doesnt matter what you get since the adapter is a dumb device.
get pcie 3.0/4.0 x4 to m.2 adapter. dont get those pcie x1
86technie
Rather just get a SATA SSD will do.
Day to day usage and gaming NVME won't make a big difference.
But if you want to get a adapter just to install NVME.
Make sure the motherboard BIOS support it and can detect it.
If not it will be waste of money.
kashix
Hooted 1TB SN850X @ $98 for external SSD.
Btw, where can I buy SK Hynix P41 locally? Got shop sell?
Kegler
Just ordered a 2tb fanxiang nvme from taobao for 500rmb
Will let u all know how bad isit soon
zhanhuju
It is a bad brand.
Of all the brands you could have gotten brands like Zhitai, Lexar, Asgard, Gloway you had to pick Fanxiang. :rolleyes:
zhanhuju
Really that bad??? Review all fake?
It is bad not to the extent that is it unusable, it definitely works as advertised and you will get your read and write speeds and they will definitely honour the warranty
But the long term reliability may not be there, hit or miss.
Buying China SSD is about choosing who uses the best NAND flash.
The price difference of 100 yuan is only 20 SGD, it makes sense to choose the higher quality ones if possible.
Kegler
It is bad not to the extent that is it unusable, it definitely works and you will get your read and write speeds and they will definitely honour the warranty
But the reliability may not be there. It is about choosing who uses the best NAND flash.
Agree on your point and I accidentally regreted after I order....oh well.....just use until spoilt bah
