My nas cannot connect after using network switch
johnsonheng
i have a feeling that the network switch that you mentioned in the title is a managed network switch. If there is no router in front of the managed switch and you connect the nas to the switch, your nas will not get any ip address.
Suggest you bypass the switch mentioned and plug your nas direct to the router to see if your laptop or computer can see the nas on the network.
I can plug it to my notebook instead of desktop as it very troublesome to keep on moving my nas around
86technie
i tried to reset t he network setting, under mode 1
but cannot reset.
  1. Mode 1: Press and hold until you hear a beep sound to restore the IP address, DNS server, and password for the admin account to default.
  2. Mode 2: Press and hold until you hear a beep, release the button immediately, then press and hold again within 10 seconds to reinstall DiskStation Manager (DSM).
Have you tried plugging in directly?
TBH TS since you got trouble, why not bring to shops that sell Synology ask them if can help
you troubleshoot.
Storage Studio or Memory World at SLS you can check with them whether they can help you or not.
Bascially now you need to configure it first set a static IP inside your router.
johnsonheng
you troubleshoot.
configure in router settings or NAS settings
petersum82
you troubleshoot.
bro,I had mentioned in my last post in this thread asking TS to plug the nas direct to the router to see if the laptop or pc can see the nas in the network, but he had not done that.
Chances are, he is using a managed switch on the nas, instead of the router with managed switch.
johnsonheng
i plug directly to the desktop , can detect from the pc, but cannot access
i plug in to the router, cannot detect, later i try to reset using method 1, while connecting to the nas, also cannot detect, i not sure if it the desktop issue or the router issue, or the nas issue
taking note that i have not configure my router since day 1
i have tried to use my notebook to detect it , also cannot detect anything
coyote
So how to configure. Can dummy guide
After 2 to 3 pages, you did not even share what's the make and model of your switch or at least draw a diagram to show how you connect your switch to the router?
Many already said, if yours is a managed switch, go read the manual how to set it up. If it's a $28 TP-Link unmanaged switch, there's nothing to setup. You just draw us a diagram how your switch is connected to the router and how your Nas is connected to the switch.
This is practically a easy peasy stuff and yet without you sharing info ... Everything looks like black box.
Even clearer, how you connect previous and how you connect now?
johnsonheng
should i reset against using method 2,
sacredrays
ur first scenario means what? cannot access as in what? can you enter your nas using web browser entering the ip?
johnsonheng
later i take a photos, and GPGT
green72
Ur Synology nas hv 2 lan port? If hv, maybe u plug to wrong one. Connect Lan 1 to router lan port.
If u can access ur asus router, go and check if ur nas is connected. Under admin page -> network map, click clients icon and under client status check wired. If u see synology listed, write down the ip and use that ip in browser to access nas.
johnsonheng
johnsonheng
i have plug out my lan port on my nas to the other lan port in the nas, it still cannot be detected
johnsonheng
if i connect the nas directly to my desktopvia rj45, i can use the browser to access the nas admin page,
if i connect it to the router, i cannot access the admin page as it is unable to detect,
i suspect it either the nas setting or the router setting, but i have not meddle with the router setting before,
i do not know why the nas cannot be detect even i have reset the nas.
i thinking of resetting it using method 2
nas lan port 1 connect to router
nas lan port 2, connect to my notebook, then i try to access to admin page to have a clear picture.
sacredrays
like that u can try connect direct to pc,
then u redo the network settings in the NAS admin page via web browser.
arbo do a mode 1 reset? https://kb.synology.com/en-us/DSM/tutorial/How_to_reset_my_Synology_NAS_7
your nas should be plug to your router/ switch instead now.
luei74
Ah Heng what they want is your connection diagram to set up the NAS and your router. Not your NAS and router pictures bah 🙏🙏
