MyRepublic fibre - Part 4
danxiaogui86
how is MR's reliability to stay connected (uptime)? are there regular downtimes?
So far when i'm on MR connection. My Uptime is 100% other than those planned maintenance. That also depend on which exchange you are connect to, mine is Ayer Rajah exchange. Usually those planned maintenance are in the wee hours of the night such as 2am - 6am.
heatzz
Guess I might head down to 1 of the MR counter for more info.
Most probably will sign up for MR since my line is ending on Sept.
So if I sign up for MR, I just need to wait till March for installation or it might take even longer then March depending on my queue since I guess there's quite a number of people waiting as well?
danxiaogui86
Check your pm :)
Yes, you will still need to wait for march installation and base on 1st come 1st serve basis. Cheers!
xRenol
the ping looks right but upload should't be higher than download. hmm.. could you try with a different device and cable?
My result using direct cable connection to the ONT.
Anyone on PURE 100 Mbps is able to hit around 90+ Mbps using direct connection to the ASUS RT-N15U router?
Raceworld
just got a sms that i would get a call in late march to schedule for installation,looks like a lot peepur queuing :(
Just Me
on the first day it came out leh :(
Well, they called me a few days later after I applied and told me I will be receiving a call near end Feb to confirm.. dunno true or not.. also applied on the 1st day..
hayashl
Bros,
Which router do u go for Ultra 1 gbps fibre plan?
I have no router at the moment. tks for the input :s12:
Raceworld
yeah i got that call too but u didnt receive a sms ?
danxiaogui86
Asus N15U is designed to support up to 700Mbps for WAN to LAN throughput.
100Mbps is not a problem for that.
danxiaogui86
Bros,
There 3 router to choose from :)
N56U/AC56U/AC68U
All 3 can support 1gbps for their WAN to LAN.
How to determine which router to go for, depend on what your wireless devices priority and allocation like.
