MyRepublic fibre - Part 4
xRenol
thanks alot, damn dumb. didnt know i had to do it. just called MR and had to pay $50 for it. =\ .. using SH prevly
MR is using dynamic PRIVATE IP by default which does not support port forwarding whereas SH is using public IP.
IMKIEL
Gee. Thanks..
I changed my SSID name n pw.. the default set earlier this noon still can be seen n the speed is faster. Y is that so?
tuckloong
speed tonight :) anyway must express me thanks for a memorable world cup 2014 experience with MR MR :) jia u jia u
wilflare
anyone knows why I'm still getting 320Mbps behind my AC68U?
tried latest firmware
tried latest merlin
tried merlin 4422
- same problem
- last check direct ONT - speeds are normal
mister38
tried latest merlin
tried merlin 4422
- same problem
update latest firmware > do a hard reset on router
Lehnsherr
it used to work fine until recently though :/
sigh oh well... guess I'll go down tomorrow. don't really like to deal w Avertek (bad exp over GPU)
If it used to work fine until recently its enough evidence to point towards a hardware failure of the router. Direct to ONT works fine puts the nail in the coffin.
xRenol
Gee. Thanks..
1. Did you save the SSID on your devices?
2. Are you using Frequency 2.4GHz or 5GHz?
imacbie
Unbelievable!! The power button failure issue has gotten to me!!
So damn funny!! I had thought the network was down... But my devices cannot see any network
Walked up to the router press the power button, tada! The router lights up! (I have my router in stealth mode)
wilflare
thanks. guess I'll get it exchanged then.
is it with MR (I bought it from MR) or do I need to find the Asus distro? Is it Avertek or Ban Leong?
tried before. nothing works
Darklord
MR just lost another customer.
Jumped ship to the men in black.
CSO very quick n professional when answering the calls n webchats.
Even the guys at their retail counter.
Those on budget can stick with purple.
I'm going premium from now.
sunnyee
me too, joining the wagon next month
Just Me
Anyone is suffering from very slow speeds when uploading to cloud sites like box.com?
Used to be very fast at 4000-5000kbps.. now it's struggling at 200kbps or less :(
Also speed to china sites is inconsistent. When downloading from baidu pan, the speed increases to about 15-20Mbps at the beginning at will suddenly drop to 50-100k when approaching the middle of the download for a while then increase slowly again..
xRenol
FYI.
If your concern is the long waiting time for OpenNet to activate the Port 2 of TP, some customers mentioned that they waited 4 to 6 months. Not sure about Fibre Takeover.
