[Printer] Laser Printer questions lip lai !!!
theToners
sian. my toner spoilt i think. check the toner and missing one line of coating which resulted non-printing throughout the page of that line. :(
toner only 30% used, and lexmark told me to get a new one ~@#$%^&!
anyone has idea of fixing the toner is feasible. :(
Yes it is spoilt. No choice you have to buy new cartridge already. I wouldnt recommend Lexmark. Though the printer is good but the cartridge is expensive and hard to source at retail outlets. Unless you call them directly.
theToners
which laser printer cheapest?
Depending on the features that you need :/
which brand of toner cheapest?
Brother toner is the cheapest but you have to maintain the drum.
Next follow by Fuji Xerox, only consumables is the toner. No drum worries.
Cheers ! Hope this helps !
shamuslee
no way to repair? like very wasted :(
sigh!
thanks anw!
kikomi
I'm thinking of buying a toner for my Samsung printer ML-1660 at the PC Show next weekend. Will the PC Show sell Samsung toners? And roughly how much is it retailing in Sim Lim, 'cause I would like a price comparison.
Thanks :o
ComputerTime
Hi, May I know do you do anything to the toner cartridge? Just wondering how come it will have one line of coating missing.
I am planning to get a laser printer, just hope that this sort of things will not happen to me.
Thanks.
ComputerTime
Not really since toner is in solid form. Wouldn't really dry up but will stick together under humid condition. If the storage condition is right, should be no problem to last a while.
Laser Toner Cartridge Care Damien – 84157721
Tips to Getting the Most from Your Laser Cartridges
Follow these tips to keep your laser printer cartridge in top condition.
1. Do not attempt to open the cartridge.
2. Do not leave the cartridge in motor vehicles for any length of time, as even on a cool day the temperature can exceed safe levels. Doing so may distort the plastic in the cartridge.
3. Please store cartridges in normal room temperature.
4. Some parts in these cartridges, for example: drum, are light sensitive and can be damaged when exposed to excessive light.
5. Gently shake the cartridge side to side before loading into printer.
6. Once loaded, do not meddle with the cartridge and change only when prompted by printer.
7. All cartridges are covered by PrintCasa six month warranty against defects.
Thanks for the responses.
Can I conclude that the printer should service me for years without any problems? Singapore is a very humid place.
power789
can recommend me the best laser printer available to home user in the market currently? particular about print quality and DPI, price wise not really a concern as long as its worth the $.
btw whats the max amt of color a laser printer currently used? still 4? inkjet is 6 right?
I saw some really good ones, but they are too big, more for manufacturing companies.
theToners
Thanks :o
Original is around $102 for 1,500 page yield. As for sim lim, if authorised dealer it may be $10-$20 cheaper.
As for compatible it is $59 same page yield.
Cheers Damien
theToners
Thanks.
Hi Computertime,
Dont worry about it. This is a manufacturing defect for Lexmark toner cartridge. Not the fault of the printer.
Chances of you being affect by this manufacturing defect is pretty slim.
Cheers,
Damien
theToners
The best printout quality of color is still by Fuji Xerox SLED series. 2400 x 1200 DPI.
Depending on what features do you need like print scan copy or print only or 4 in 1??
If you dont need duplex than it would not be too big.
Yes the inkjet with the best print out quality still uses 6 ink cartridges while colour laser uses 4 toner cartridges.:D
Edit. Large format inkjet printer of some brands have 12 ink cartridges
CrunchTime
Can someone recommend me a good wireless printer with the following:
1) Monochrome laser
2) 4-in-1, otherwise 3-in-1 without fax
3) Duplex (if possible)
4) Supports Airprint
5) Good print quality
I'm currently using the Brother MFC-7340 but hate how it is not a wireless printer and does not support airprint.
Budget about 400ish?
Thanks! :)
consigliere
Hi, can recommend Mono laser printer with the spec below best bang for buck?
1)Monochrome
2)4 in 1
3) Network connectivity ( No wireless nvm)
4) No need full duplex
Thanks in advance
Ender
1. Mono or Colour
Mono
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
Just Print
3. Printing capacity per month
Low
4. Budget
Cheapest
5. Other extra requirement like wireless, iphone printing etc.
Wireless, Duplex would be good, but not neccessary.
Jacky2000
1. Mono or Colour
Color preferred.
3 in 1
Super Low
4. Budget
reasonable pricing
Wireless
moomooo
Looking for a color laser printer for home-office use - print, scan, copy features most important!
Thanks.
ComputerTime
Hi Computertime,
Cheers,
Damien
Thanks Damien.
csc12345678
I have a Canon MX-886. I bought this model cause it can do duplex ADF scanning. I like the inkjet printer except that I also print quite a lot of pdf in bw. The printer ink runs out quickly.
So what are my option ? I should get a laser printer to just print duplex BW or should I get one that can do duplex scanning and replace the inkjet printer ?
Thanks.
theToners
1) Monochrome laser
Thanks! :)
The HWZ tech award editors choice 2012 is Fuji Xerox M205fw.
Mono 4in1 and wireless.
Printer quite valued for money at $309+$30 ntuc vouchers last show.
However, dont have duplex and airprint :/
You may want to consider Brother MFC-7860dw
Mono 4in1 wireless duplex and airprint
Last show $398.
theToners
1)Monochrome
2)4 in 1
Thanks in advance
Fuji Xerox M205f. (recommended)
Last show $269 + $30 ntuc vouchers.
Got Network and manual duplex.
Brother MFC-7360
Last show $248
