CaptainFantastic
- Dec 15, 2015
JannPaul didn't have the setting I had in mind while I was browsing through their catalog. So after watching some videos I came across this video from Fire and Brillance which was very close to what i wanted! Quickly email Casey the video and he roped in Paul to help design my ring!
Here's the video that i saw
Paul explain to me how this ring design is actually quite dated and has several bad points
1) The design is old fashion
2) The surfaces are flat which are bad at reflecting light
3) The prongs are too tall which has durability issues if you knock into hard surface
4) The band is reversed tapered which actually makes the diamond look smaller
Overall the setting is not durable and does not do the diamond the justice that it deserves!
So I told Paul that I wanted the prongs to lift the diamond such that I can see the pavilion from all sides, tapered ring and with sharp prong tips. Paul was very understand and gave me suggestions on how the ring design can help accentuate the diamond which we are all interested in
Not long after, Paul told me that my gf's ring size coincidentally is exactly the same size that he is using for his behind the scene research project that he is doing for testing of 3D lighting using ray tracing! In case you don't know ray tracing, it is the calculation of light reflection from a reflective surface. So imagine a SIC with 57 facets aka mirrors! That is a lot of internal reflection that needs to be computed to render. Paul told me even with his pc using 4 2080TIs they are running at full load while rendering.
So after a week of designing and rendering, Paul showed me 3 different design and of which the 3rd design he rendered in his 3D project. Take a look!
Paul's suggestion was to go for the 3rd ring which I totally agree as it very beautiful. Casey also helped to hyper render it into images!
So the waiting time is 6 weeks! Can't wait to see the ring in person, in the mean time I asked for a wax model of the ring for memorabilia which will take a week to print.
Really thankful how Casey and Paul have gone above and beyond my expectations. The amount of effort and dedication is a real testament to show how much they believe in their product and how much they put their customers first. If this doesn't convince you I don't know what will!
Nice ring! Looks impressive! Is the hand model ring video the same as your ring design? Never seen this kind of video from them before. Like your thin band.
