- Mar 31, 2001
Rich get richerTwo of my friends doing it. I think it is stupid.
Both are not poor. They are condominium owners.
It seems doable but you live with the silly inconvenience.
Poor gets poorer
Cheapest fiber is only 24-25$ per month.Rich get richer
Poor gets poorer![]()
$16 * 12 =$192.00 per yearCheapest fiber is only 24-25$ per month.
Cheapest 4g plan from eight is 8$. Need to buy 200$ router also. How much you can save per month? Less than 10$ for 2 years.
Assume $240 for router
$240 / $192 =1.25 years to break even
For me I base on $31 bb plan, so savings is $23 per mth
$23 * 12 =$276.00
$240 / $276 =0.87
Less than one year break even![]()
Tplink SIM card modem. In the long run is worth it
Using dlink Lor, 5g router that can’t get 5g in my areaWhich router are you both using?
end up I using 4g $8 plan
Erm. You got how many pax?I am thinking of getting the Tp Link MR400.
Is this ok for light usage and also home security camera?
number and type of devices?
Can try lah, moral of story is don’t get so expensive sim router1 pax. TV, laptop, phone and security camera.
keep your original router in case older devices cannot connect to newer wifi network (6e/7). Can do bridge mode to get connected to the old router
Simba I dun use leh.Ya not going to get those expensive ones. 4g LTE router is enough.
Do you know whether it supports Simba or Eight sim cards?
got one d-link model like more value for money than tp-link. forgot the model name maybe just search d-link 5g router. i think 200++ sgdYa not going to get those expensive ones. 4g LTE router is enough.
the tp-link 4g deco x50 already 200+... unless u take the really low end modelOk. Maybe I will go try it out. Thanks!
Omg $200+ is too expensive and I don't need 5g.
The difference between using 4g vs broadband is really like day and night for simple youtube buffering.$16 * 12 =$192.00 per year
$23 * 12 =$276.00
$240 / $276 =0.87
why don't you try to tether data from your phone to laptop first, to see if you can accept the latency of using 4g data..1 pax. TV, laptop, phone and security camera.
no idea.. u want wifi5 only meh..? might as well use your phone tether liaoSaw a good price for the MR400. Less than $100. Worth to get this?
Paiseh. You use what model again? I've tp link mr200
