SIMBA Fibre Broadband
AMIAPIG
Some testing that I did previously & current latency, speed
SIMBA did improved on their latency & some test servers. Some even better when comparing to M1.
M1 500MB - Tested during last year Aug 2024SIMBA 10GB - Tested during last year Aug 2024
Test case - using DECO BE85 speedtest - 10GB LANIn Gbps otherwise unless stated
StarhubNot testedPing: 141 DL: 148Mbps UL: 321Mbps
SingtelNot testedPing: 211 DL: 147 Mbps UL: 294 MBps
M1 LimitedNot testedPing: 3 DL: 8.15 UL: 7.7
ViewQuest - SingaporeNot testedPing: 3 DL: 4.34 UL: 4.56
PT FirstMedia - SingaporeNot testedPing: 2 DL: 1.8 UL: 1.82
Pacific Internet (S) - SingaporeNot testedPing: 3 DL: 5.43 UL: 5.36
NewMedia Express - SingaporeNot testedPing: 3 DL: 5.78 UL: 6.15
Contabo - SingaporeNot testedPing: 3 DL: 3.47 UL: 1.73
Fdcservers.net - SingaporeNot testedPing: 56 DL: 2.15 UL: 7.25
Test case - using iPhone 15 ProMax 6E WIFI with DECO BE85 - 1 metre from routerIn MBps - Tested during last year Aug 2024In MBps - Tested during last year Aug 2024In MBps - Tested on Jul 2025 (Upgraded some switches & routers & DECO BE85 is in AP mode)
SingtelPing: 7 DL: 490 UL: 489Ping: 235 DL: 1108 UL: 153Ping: 40 DL: 1279 UL: 1153
StarhubPing: 6 DL: 309 UL: 483Ping: 147 DL: 9.24 UL: 334Ping: 6 DL: 1328 UL: 936
M1 LimitedPing: 7 DL: 366 UL: 485Ping: 7 DL: 1367 UL: 1273NA
Celcom Axiata Bhd - Johor BaruPing: 18 DL: 482 UL: 484Ping 197 DL: 1309 UL: 106Ping: 44 DL: 1312 UL: 1315
Optus - PerthPing: 203 DL: 497 UL: 135Ping: 408 DL: 1175 UL: 329Ping: 148 DL: 1119 UL: 344
Aussie Broadband - PerthPing: 55 DL: 323 UL: 476Ping: 54 DL: 1286 UL: 1044Ping: 56 DL: 1317 UL: 1243
Verizon - TokyoPing: 84 DL: 488 UL: 368Ping: 272 DL: 550 UL: 219Ping: 168 DL: 892 UL: 917
Allied Telesis Capital Corp. - OkinawaPing: 114 DL: 411 UL: 240Ping: 277 DL: 1271 UL: 193Ping: 111 DL: 1279 UL: 458
HKIX - Hong KongPing: 46 DL: 95.3 UL: 86.7Ping: 44 DL: 95.1 UL: 873Ping: 40 DL: 91.6 UL: 83.7
Telstra International - Hong KongPing: 46 DL: 486 UL: 317Ping: 190 DL: 1126 UL: 687Ping: 41 DL: 1325 UL: 1312
浙江电信- HangZhouPing: 469 DL: 200 UL: 6.92Ping: 411 DL: 617 UL: 1.09Ping: 352 DL: 1119 UL: 5.59
China Telecom JiangSu 5G - SuzhouPing: 1182 DL: 386 UL: 0.32Ping: 407 DL: 1193 UL: 66.5NA
CenturyLink - Seattle, WAPing: 305 DL: 511 UL: 166Ping: 305 DL: 1125 UL: 550Ping: 252 DL: 1285 UL: 588
Relyant Communications - Washington, GAPing: 239 DL: 482 UL: 127Ping: 246 DL: 911 UL: 530Ping: 253 DL: 856 UL: 561
SIMBA Telecom - SingaporePing: 6 DL: 305 UL: 485Ping 5 DL: 1160 UL: 1064Ping: 5 DL: 1360 UL: 1292
Saw reply about M1 plan compared to Simba Plan. Not sure which better.
As for SIMBA free installation, does it include full installation (incl. router) and whats the process like?
As for M1 installation, is it free and whats the process like?
As for support/CSO for both, how reliable isit when I need help with service?
Will appreciate any help with this as im newbie :(:(:(:(:(
You may want to read the posts in the first page of the sticky thread and come to your own conclusion.
My personal opinion is that you should avoid SIMBA as you seem to expect quite some support from the ISP. M1 will be way better than SIMBA based on your description. You may want to ask further thread in M1 thread.
Sticky Thread '⚡️💻 [Official] README First! 2025 SG ISP Comparison & Latest Promo Deals! ✨' https://forums.hardwarezone.com.sg/...sg-isp-comparison-latest-promo-deals.6665380/
Nakedtoes
I tried both M1 and simba.. I can tell u this.. I banned and boycotted simba forever.. So u go decide yrself.
But need to pay NLT Service Activation Fee of S$61.04.
Indeed this is a major difference.
1) SIMBA 10Gbps plan without digital voice:
https://simba.sg/static/media/fbb/assets/cis-broadband-10gbps-720.pdf
1.3.2. SIMBA shall waive the one-time $61.04 for NetLink Trust (“NLT”) service activation
charge (where applicable); and one-time $118.00 charge for Optical Network Terminal
(“ONT).
2) SIMBA 10Gbps Broadband with Home Phone Line
https://simba.sg/static/media/fbb/assets/cis-home-broadband-720.pdf
1.3.2. $61.04 for NetLink Trust (“NLT”) service activation charge (where applicable);
1.3.3. SIMBA shall waive the one-time $20.00 home phone line activation charge;
1.3.4. SIMBA shall waive the one-time $198.00 charge for Optical Network Router;
1.3.5. SIMBA shall waive the home phone line charges, at $5.00 for 30-days service in
advance, for the period in which the Customer has paid for their SIMBA Fibre
Broadband billing cycle in advance.
hoision
Simba could be transiting to use ONR. So the term ONU is used to include both ONT and ONR.
https:[//]support.simba.sg/hc/en-us/articles/48695249691801-I-ve-collected-the-10Gbps-ONU-how-do-I-set-it-up
oh no, if they change to ONR i think i will switch out
Interesting move that SIMBA is also adopting ONR. Hopefully it will offer both ONT and ONR (just like M1) to give the users choices.
Most power users will avoid ONR (Singtel and WC) since the ONR will be the main router for the home network and you will have some limitations to use your the router behind the ONR. But ONR may not be a bad thing for average users who want to save one router in the DB Box.
The router in the picture will need to be configured in AP mode (losing many features) in order to avoid Double NAT. If you use the router in router mode, then you will be in a situation called Double NAT.
https://support.simba.sg/hc/en-us/a...e-collected-the-10Gbps-ONU-how-do-I-set-it-up
1) More about Double NAT
https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
https://support.google.com/googlenest/answer/6277579?hl=en-SG
2) More about ONT vs ONR
https://forums.hardwarezone.com.sg/...cs-of-home-networking.6653421/#post-138363236
pwillie
I’m not power user la, but I have used a Nokia router mandated by Starhub before, and the experience is terrible. I can imagine if the ONR is the same quality.
Scuderia
From the pic it seems like a Huawei OptiXstar EN8250Ts-20 ONT, same as the one issued by m1 for their xgs-pon plan. How simba is able to configure all the 4 x Ge and 1 x 10Ge ports to work together probably will need those new subscribers to do some testing.
M1 is using Huawei OptiXstar HN8250Ts-20 ONT but take note that it can also be configured in ONR mode.
Let's wait for the new users who get the ONR to report back on the SIMBA XGS-PON ONR model.
Starhub is using Nokia XS-240X-A in ONT mode, but Singtel is using Nokia XS-240X-A as an ONR.
M1 is using Huawei HN8255X6s-8X ONR for the new 10Gbps ONR plan, that has the Wireless function built-in, similar to Starhub issued Nokia XS-2426X-A (WiFi 6 AX6000 rated). Take note I do not recommend this M1 ONR plan at all. M1 6Gbps plan (ONT with free Archer BE805) is better than the M1 10Gbps ONR plan (all-in-one ONR plus Archer BE230. Both are of the same S$36.90 per month pricing for new users now.
https://www.m1.com.sg/home-broadband
https://www.m1.com.sg/support/faq/fibre-broadband-faq#accordion-fe8b6ec73a-item-195e6d7476
Can SIMBA Broadband customers who are currently in contract or recently signed up for a SIMBA Broadband plan switch to the fixed line plan instead?​
This is currently applicable to new sign ups only.
There are now subbers who are currently or gonna be out of contract soon, and also not recently signed up since they signed up > one year ago.
