SIMBA Fibre Broadband
The best speed I have seen so far is about 1.8Gbps download and 1.1Gbps upload, for SIMBA 2.5Gbps plan.
1.8Gbps download speed is in line with those dual 1Gbps plans with Dual WAN Load Balancing.
Edz_Sg
I just installed today... around max around 1.5 d and 1 u
donno is it becoz of my BTO lan cable quality....
tomorrow getting a CAT6 cable and test
Try different SpeedTest server as well. SingTel SpeedTest server seems to be the better one now.
Make sure you use SpeedTest App and not browser.
But anyway 1.5Gbps download and 1Gbps upload are good for a S$21.8 per month plan (9% GST included).
I am paying SingTel S$40.65 per month for the 1Gbps plan.
Edz_Sg
I'm using Whizcomm 1Gbps ONT mode, had upgraded to 2.5Gbps but not yet reset ONT, in order to enjoy 2.5Gbps need to reset my ONT to ONR mode... and is 2.5 split on all the ports on the ONR..
contract ending jun... now paying $35+
So now try Simba .... but I see the speedtest... like very unstable like this... at time uppppp... at time lowwww
Nakedtoes
Then for Asus TX 6000 for snapdragon 8 Gen 2 phone should get what speed?
To test the real capability of an Fibre Internet plan, you should really use WIred Test using a PC/Mac with 2.5G network adapter.
If you use wireless to carry out test WiFi 6 router, it is difficult to get above 1.6Gbps download speed. For mid-end AX router like Asus TX-AX6000 (China version of TUF-AX6000), most likely you may not hit above 1.2Gbps download speed.
Nakedtoes
If you use wireless to carry out test WiFi 6 router, it is difficult to get above 1.6Gbps download speed. For mid-end AX router like Asus TX-6000 (China version of TUF-AX6000), most likely you may not hit above 1.2Gbps download speed.
yeah i understand to test full speed is use lan.. i just want to gauge roughly what mine new router with new simba will get..
bueysongLaiQikuamai
Hi im new to this simba fibre home plan, when signing up the plan does it come with the router? or we need to source our own router?
Does it come with ONT also?
ONT yes -- one 2.5G LAN port, no digital voice.
Router No -- you have to source for your own router. It is better to get routers will dual or more 2.5G ports, like Asus TUF-AX6000 or GT-AX6000, or you can get cheaper China versions (Asus TX-6000, Xiaomi BE7000, etc).
i1magic
Same as you..
Worse is my M1 terminating tomorrow...
Looks like CNY no internet.. only can use mobile data🤦‍♂️
Wah, jialat.
Near CNY, cannot have all this changes. Must send car for servicing and checks. Anything goes down during CNY, then siao liao.
Nakedtoes
For nlt installation.. Will the technician come in to house? Or they just do outside.? No phone call before hand.. No sms also..
given
wow, NLT suppose to come yesterday 9am-12pm , waited whole day, no show, no call, no text.
suppose to do ONT today 9am-12pm too, lets see how it goes.
Nakedtoes
really cheespie... knn email them to complaint
kennethoka
I think if NLT no come to activate, Simba ONT come also no use. usually if NLT postpone, the ONT will also postpone.
usually the NLT tech will ask the customer to sign some paper to prove that they had activate the port and tested the signal strength.
If the customer didn't sign anything and yet the port is activated that means, the NLT tech activate the port and without testing the signal from inside the house and the tech 'sign on-behalf' for the customer.
given
If the customer didn't sign anything and yet the port is activated that means, the NLT tech activate the port and without testing the signal from inside the house and the tech 'sign on behave' of the customer.
ahh , nope did not sign anything yesterday. just receive whatsapp reminder ONT 9-12 today .. still not here lol .. will they come and realise no NLT ytd ?
