SIMBA Fibre Broadband
Palary
Seems like your router should be fine. I Felt sometime not right so I went feedback to them with screenshots taken from speedtest.
After all, I can't complain much for the price just that quite disappointed that the speed not even close to 1gpbs.
Below is what's they had replied and will take sometime to go ping pong with them but I guess only direct wired connection it will be able to hit more than 1gbps.
Quote+++++
Could you kindly confirm if you have access to a laptop or computer that can be directly connected to your ONT to verify the speed?
We kindly request you to perform the following steps to assist us further:
Conduct a speed test using both the 5 GHz and 2.4 GHz frequencies.
Establish a direct connection between a laptop/computer and your ONT.
Kindly take note that SIMBA offers a high-value Fiber Broadband Plan utilizing 2.5Gbps GPON technology. It is essential for customers to utilize equipment that supports 2.5Gbps mGig (2.5GBASE-T) to achieve speeds exceeding 1Gbps.
Unquote++++
during installation, he did used a LAN wired to his laptop. ookla speednet shows 1800 mbps download speed
Read HWZ Forum Rules!
sglandscape
my viewquest 1gbp gets about 650-700 mbps , I'm using asus RT-AX88U. Now with simba I'm getting 200-300 nia....
If you're doing the test over WiFi, it's not helping your case that the issue is simba. different test servers have different sensitivity to latency, and that could be the reason why they test differently. Retest on LAN
This is the right way to carry out the test. 1.8Gbps is not that high for a 2.5Gbps service but quite okay considering the price of S$21.80 per month.
Your RT-AX88U does not have a 2.5G port and that indeed will limit your internet speed to 1Gbps. If you carry out OOkla SpeedTest you should probably get above 900Mbps. If you get much lower results (say below 800Mbps), then there is a problem and you need to troubleshoot that first
Another thing, if the wired test result is above 900Mbps yet the fact it is not exceeding 1Gbps bothers you, you will need to change your main router to 2.5G capable routers like Asus TUF-AX6000 (dual 2.5G ports). Get a USB to 2.5G adapter as well if you do not have a 2.5G enabled wired device. Then you can carry out wired test just like the SIMBA installer.
For wireless test, it depends on may factors. You need to get your wired test results proper before troubleshooting wireless results.
allanzzz
If there is no issue with wired, i suppose you need to resolve any wireless issue yourself to be fair to them?
Would probably still stick to my mesh with 1 Gb LAN.
those 2.5 Gb mesh are quite expensive.
Deco X80 cost $600 and their 2.5Gb 5 port switch cost $200+, have to check out more pricing.
My recommnedation is usually to go with Asus AImesh.
Main router -- TUF-AX6000
Mesh node -- TUF-AX6000/TUF-AX4200
If you do not mind no locale warranty, then you can get Asus TX-AX6000 (China version of TUF-AX6000) at a very good price from Taobao. Of course you can also go with Xiaomi BE7000 or BE6500 Pro with quad 2.5G ports.
2.5G swtiches are also very affordable if you do not mind no local warranty (below S$100). Please refer to the 2.5G home networking thread.
https://forums.hardwarezone.com.sg/threads/2-5-gbps-wired-home-network.6347648/page-13
soulpower11
Quote+++++
Unquote++++
When I feedback to SIMBA that i wasn't getting anywhere near 2.5 Gbps on my router (RT-AX86U), this is what they reply.
We understand and thank you for your feedback.
Yes, customers can get up to 2.5Gbps. However, it's essential to highlight that achieving the maximum advertised speed of 2.5Gbps may be influenced by various factors beyond our control. These factors include, but are not limited to, network congestion, signal strength, and the capabilities of your specific devices.
Again, bandwidth available at any point in time is on a Best-Effort basis. This is in line with industry standards for consumer internet access plans.
SIMBA only provides support for connectivity issues. We do not provide technical support pertaining to speed test results.
Feels like the speed you get depends on your location, that's what
Actually you should not use RT-AX86U's built-in OOKla SpeedTest app result as the CPU (as well as the whole system) is too slow to handle 2.5G WAN speed. I have the RT-AX86U myself and the built-in SpeedTest app can not really report the correct download speed for my Singtel 1Gbps plan. But when I test with a laptop there is no issue.
You may want to use a laptop with 2.5G network adapter and try again.
From the reports here, you should probably get around 1.8Gbps. Is that a good result for 2.5Gbps internet? NO. SIMBA as of now does not really deliver the right speed for a typical 2.5Gbps internet plan. But at least it is higher than what you get from RT-AX86U's built-in OOkla SpeedTest app.
The following answer is just from a template and I believe the person does not understand your test results at all. Anyway, it is very good that you post the response which should show that SIMBA is not able to sort out the speed issue as of now -- so they use a template answer.
sglandscape
The installer may be using a USB to 2.5G adapter which is not ideal either 😂 ideally should bring a mini PC along
Indeed that may not be the best but should not be a big problem in this case. Usually those 2.5G USB adpater has no issues to get 2.37Gbps which is anyway higher than the upper limit of what you can typically get from GPON ONT.
soulpower11
I see, I don't have a 2.5G network adapter right now but I tried using my phone to test, got a maximum of 1.6 Gbps down. Still not close but at least better than the router's built-in test.
That at least means your SIMBA 2.5G has pretty decent wired speed. When you get 1.6Gbps download speed using WiFi, your wired speed should be even faster. It may well be the wired speed is at 1.8Gbps as mentioned in other reports.
BTW, Ugreen USB to 2.5G adpater is pretty cheap. For example, you can get them from their official Shopee store. There are other brands as well.
https://shopee.sg/UGREEN-2500Mbps-U...o-Lan-RJ45-Network-Card-i.64922680.4428880843
dgeralds
Hi. My set up is
Asus TX-AX6000 -> wired -> Ethernet switch (2.5 Gbps) ------> computer.
I want to connect another Asus Router (1gbps) Aimesh to the internet switch.
Please recommend a cheap / second hand ethernet switch and router.
Hi. My set up is
For Asus AImesh node, just get another Asus TX-AX6000 (China version) as the price is pretty good. Or if you want to save some bucks, then you can choose other options, like the RT-AX3000P which is at about S$80 BNIB from Carousell
Or you can get another Asus China version router as the AImesh node.
Asus China Taobao Flagship pricing info for reference.
TX-AX6000 天选路由器 (TUF-AX6000 China version): RMB799
TUF小旋风Pro (TUF-AX4200 China version): RMB 599
TUF小旋风 (TUF-AX3000 v2 China version): RMB419
RT-AX57 China version: RMB349 (similar to RT-AX3000P)
For 2.5G switch, you can refer to the discussion here.
https://forums.hardwarezone.com.sg/threads/2-5-gbps-wired-home-network.6347648/page-12
slash
I guess even if you test with LAN connection, your router needs to have at least 1x2.5G WAN & 1x2.5G LAN port. PLUS your computer's LAN port is also 2.5G. In order to get the max bandwidth for testing.
My pc which when connected with 1G (both SH and MR) can achieve 900+ up down. BUt when switched to Wifi6, the max i can get is 750+, and it has almost diagonal line of sight with router and a wardrobe blocking in between.
So wireless test is not the best way. Anyhow, like other bruhs mentioned, for this price. Can't complain much.
50+ per mth versus 20+ per mth...
raychoy
Simba fibre broadband 2.5g does not include digital Home Line. What is the best alternative to port the Home Line to ?
Scuderia
Anyone recently received invitation emails with the $50 mobile credit to sign up with them? My area is Simba broadband ready but yet to receive their email to sign up. I understand that if I sign up directly without their invitation link will not get the mobile credit.
ngbc
Normally. those registered should received invite email & given link to signup within 3 days when their area is ready before they open to public. You may want to contact the customer support team
