NewNew
- Apr 25, 2002
Got this weird reading. Restart my com and still get same result.
Any advise? Over 100deg and weird fan rpm.Should I try remount my hsf?
Thanks i1magic for help.
After some trial and error, I think I found the problem:- Software Conflict. Using only HWMonitor now, normal reading, but when I on 2nd software like speedfan or asrock tuner, those errors return.
Sharing my experience:
Tried remount hsf, replugging all cables, didn't work. Think I didn't mount well cause core temp went up abit.![]()
Gathered from some reading, it's either:
- Faulty sensors and suggest to live with it or RMA.
- Wrong reading with HWMonitor. Seems normal/common to have wrong reading on SYSTIN, CPUTIN, AUXTIN and TEMPIN1/2/3/4.
- Might be software conflict. Got this information from this thread. Post#2853
[Official] ASUS SABERTOOTH Z77 Owners Thread/Club
Most importantly, as long as your Core, GPU and HDD temperature are normal/healthy, you are fine!
Will monitor for few days and update again.![]()
Back with updates!
Been monitoring for few days. Everything is normal on HWM now, as long as I don't launch a 2nd temp software. No more weird temp/fan rpm reading like the above. Can confirm that it's software conflict that causes it.
Glad to know that it's not my MB sensors that gone crazy.
