10Mins after boot up~
Not sure if why the core#2 always running slightly warmer![]()
Taken with a/c on
Taken awhile ago.
@i1magic - Mine is Gigabyte GTX 670 2GB Windforce
@hlots123 - Thanks for helpingdidn't know how to do it.
Wow ... not bad. GTX 670 temp is quite good leh.
My Evga GTX 680 usually 46 degC to 50+degC.
My recent temps... I myself find it hard to get Max Temps so uniform so screenshot it down
Got this weird reading. Restart my com and still get same result.
Any advise? Over 100deg and weird fan rpm.Should I try remount my hsf?
What is "CPUTIN"? How come 127degC? Anybody can advice what's wrong?
Thanks i1magic for help.
After some trial and error, I think I found the problem:- Software Conflict. Using only HWMonitor now, normal reading, but when I on 2nd software like speedfan or asrock tuner, those errors return.
Sharing my experience:
Tried remount hsf, replugging all cables, didn't work. Think I didn't mount well cause core temp went up abit.![]()
Gathered from some reading, it's either:
- Faulty sensors and suggest to live with it or RMA.
- Wrong reading with HWMonitor. Seems normal/common to have wrong reading on SYSTIN, CPUTIN, AUXTIN and TEMPIN1/2/3/4.
- Might be software conflict. Got this information from this thread. Post#2853
[Official] ASUS SABERTOOTH Z77 Owners Thread/Club
Most importantly, as long as your Core, GPU and HDD temperature are normal/healthy, you are fine!
Will monitor for few days and update again.![]()
May I know what is your CPU? i7 Extreme?
And your GPU?
I was thinking of reseating my HSF ... but it'll be alot of work man ... that's why keep postponing ... LOL!!
Currently, I think my cpu temp are quite ok ... but I really hope to find the time to clean and clear the HSF dust and reseat it.
My Evga GTX680 temp is usually 15-25 degC above room temp. I think the only way to reduce the temperature is to modify the cooling.
I realised that the more programs that we have running will affect the temperature readings.
Below is the readings I took with only uTorrent, Skype & some other programs running with NO browser running.
Room temp : Aircon set at 25degC
With Firefox (30 over tabs opened) & Chrome (9 tabs) running also ....
