yes i just submitted got the email shortlyno more pdf, they will send a email to you after submitting
Some say fail few times then pass using the extreme right side Egate
You can register for MACSv02? Finger Print Scanners up & running?yes i just submitted got the email shortly
yes i submitted via the link so later i will go try for finger scanners..You can register for MACSv02? Finger Print Scanners up & running?
UnlikelyNeed to print out the email?
How?yes i submitted via the link so later i will go try for finger scanners..
all finger scanners are down/disabled/not in use for like afew mths or smth liaoyes i submitted via the link so later i will go try for finger scanners..
Renewal my passport recently and need to re-register for finger print but custom officer reply not sure when finger scanner can be up. Had to use manual lane for the time being.all finger scanners are down/disabled/not in use for like afew mths or smth liao
There are checkpoint fb groups that always have ppl asking. It's down for mths rdyRenewal my passport recently and need to re-register for finger print but custom officer reply not sure when finger scanner can be up. Had to use manual lane for the time being.
Do update here if finger scanner can be up. thanks
If before entering Penang you didn't submit MDAC, then very likely you can't use E-Gate but can try...is the manual counter finger print thingy the 4 fingers and thumb scanning?
i have not registered for MDAC but went to Penang back in Jun and remember doing the finger print scanning.
any chance that i dont have to go through the manual counter anymore if i registerer for MDAC?
thanks! will find one weekday to go try try. manual counter probably not so long queue also if i need to go to manual counter.If before entering Penang you didn't submit MDAC, then very likely you can't use E-Gate but can try...
2 forefingersis the manual counter finger print thingy the 4 fingers and thumb scanning?
2 train of thought here. the kiasi kialan ones will tell you best to match the entry and exit stamp.If I register tomorrow via manual counter when entering, can I use e-gate when exiting same day or still have to use manual counter?
Some Officers say can Exit via E-Gate but not always successful.If I register tomorrow via manual counter when entering, can I use e-gate when exiting same day or still have to use manual counter?
